P1000 Cage chop
Blubeerbuggy
Blubeerbuggy
5
Kcmo
I'm working on my cuts now. That B pillar is being a pain in the @ss! Only place I can see to get 4.5 inches out is where the headrest V bar is. Anyone have a work around that?
Reactions: Papaandhistoys
Rocket
Rocket
277
909
Bullard, Texas
4” off all four corners..
0E42A1B4 619A 4EE8 A9DD 3D7B74ECC5CD
ToddACimer
ToddACimer
Pioneer 1005-2
3,558
14,599
Oshkosh, Wi
I cut my b-pillars at a z. The outside was about an inch longer on the top at the outside and then a out 1/2" taller on the bottom on the inside. This way I could over lap the 2 pieces and keep the gussets on both sides. I also sleeved mine with tube
Hopefully the pictures help
PXL 20210101 1506143442
Blubeerbuggy
Blubeerbuggy
5
Kcmo
View attachment 244612View attachment 244613
Yes that helps a bunch, thanks. I'll post pics when I'm done with it!
pct
pct
Lost in the hills
790
1,023
Letart WV
Welcome to the club bigcountry87 from Wv what part are you from. There is a post called the top cop club some where on the forum when I shopped mine I posted several pics I took out 4.5 on mine I cut the tubes with a tubing cutter and sleeved and mig welded hope it helps
Paul
Tommyp
95
169
Covington La
I need to chop mine to fit in the toy hauler. When you cut the a, b, and c pillars, do you have to change the length of the upper bar front to rear?
ToddACimer
ToddACimer
Pioneer 1005-2
3,558
14,599
Oshkosh, Wi
With 3" removed, I did not add any between the a and b pillar.
Tommyp
95
169
Covington La
This is a 1000-5 correct? Todd this is 3 inch from all 6 uprights?
Rocket
Rocket
277
909
Bullard, Texas
4” chopped ,, nothing added or removed
JenElio
JenElio
64,150
601,957
Loxahatchee, florida
No, I cut mine 4” in the front and 5” in the back without changing the length
Is it a P1K5? You got any pics of this chop? Maybe a side view?? I was thinking doing 4 all around but may like the 5 at the rear
Reactions: Remington
bigcountrywv87
bigcountrywv87
West Virginia
Paul
Swiss, WV here
Reactions: pct
