P500 Center console
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Received my armrest today and was really surprised when I opened the lid to see there didn’t appear to be much storage. I’m thinking it may be a good place to mount some switches and a volt meter for the aux battery. I do have to admit I didn’t inspect it thoroughly so I may be wrong about available space. What do you think @Chooglin o_O
207,989
He don't know Choog! HA!
Chooglin
Oh it has very little storage , but there isn't any other console out there (that I could find) that was narrow enough to fit and not interfere with the seat belts. It's the cup holders that take up all the storage space.
I will be removing those cup holders and making up a new tray to go inside the console , then cap off the openings where the cup holder use to be.
Eventually I will most likely just make an entirely new console , but this will work for now. I just needed to buy something to start out with. I really like the Kolpin console but I think it would just be to big.
Bench Center Con 4b840b041c167 Screenshot 2019 03 26 04 51 15
I think I can also use a larger console with this mounting system I came up with , it mounts the console above the seat belt latches , so that is no longer an issue.
Reactions: Eltobgi
Eltobgi
Eltobgi
4,599
15,186
North Dakota
View attachment 117650 View attachment 117651
For the price it really isn’t bad! First and foremost it is an armrest! I think I will explore whether or not it could hold switches and forget about using it for any type of storage!
I’ve began completely re wiring the mini Beast and will have to mount more switches before I can complete the job so its either a few options on the dash or the console.
But I’m getting tired of working on her and want to ride now that snow has melted enough to do some hill climbing and tackle some local trails.
Reactions: Mudder and Chooglin
Chooglin
I really like the idea of mounting switches in there. You have to remember though , that means you would have wires running in to the console and when you go to remove the seat bottom , that could be a pain!
Reactions: Eltobgi
Chooglin
I agree , I have a few things to get done before Takeover , then it's time to enjoy the warmer weather and do some riding
Reactions: trigger and Eltobgi
Chooglin
Reactions: Eltobgi
158,153
Chooglin
Might be too wide Chooglin?
No , the mounting bracket is above the seat belt latches , so width will not be an issue now. My only concern with the width now , it mite jab me in the side. It's only 1 1/4 wider than the console I bought , so it should be good!
Screenshot 2019 03 26 14 09 38
Chooglin
@trigger I will have this all finished up over the weekend and I will post up some better pics. After everything is put all back together, it will be easier to see how this will work out.
158,153
That 1 1/4" is what I'm referring to, hope you're right and it works for you though. ;)
Reactions: Chooglin
Chooglin
This prototype work sucks. Last night I put the seats back on to check for fitment and clearance on the mounting bracket and what do you know , it's about 1.00" shorter on the height than what I wanted. I had to start all over again , making a new bracket.
I could have used the first bracket but it wasn't to my liking and if I don't make it right , it will just drive me crazy!
158,153
I couldn't find anything suitable back when so I understand what you're going through. That's why I just built one out of wood to the dimensions I wanted. Guess I didn't realize how many guys wanted a console, maybe I should make up a few? Takes some time though as I riddled it with staples for the vinyl cover. Upholstery isn't really my strong suit but I made it work.
Chooglin
Same here , I could build the box for the console but covering it in vynyl would be where I would have a problem!
papermaker
papermaker
133
586
Lewiston, Idaho
