P1000 Cooling fan?
P1K5Dave
P1K5Dave
2,284
8,537
Petoskey, MI
I did a thread on my fan failing and the SPAL replacement. Not exactly a how-to thread but there are some tips on installation in there.
I
iwill1010
5
Florida
There is no way that the fan is supposed to push. I was a HONDA tech for 25 years, never saw such a setup on any HONDA water cooled unit. I am not saying that yours does not push, just that it should not push air forward. My 2016 pulls air. You are correct, a push fan would absolutely not work and would cause overheating. The 2021 and the 2016 use the same parts (part numbers are identical), so that is definitely not supposed to be a pusher fan. The fan blade (and motor, of course) is supposed to turn clockwise when viewed from the front, if my memory serves me correctly. How about posting a picture of that fan. I'm thinking that the blade is installed backwards. Definately should not be a pusher fan
I think I still have the fan. I look when I get home to check. How I figured it out was when I hit water all the steam would blow out of the front of the radiator. Now with the spal fan it blows out the wheel wells.
67,665
If you are replacing with OEM, need to look into the 2022 upgraded fan.
Reactions: Lady01
mlynch001
mlynch001
193
879
Dardanelle, AR
I never doubted that your fan was pushing air out the front, just saying that it should not do that. If you get the chance, post that picture of the fan. If it is wired backwards or the fan is on backwards, I wonder how many others are having the same issue? Did the fan pulling air in the right direction fix your cooling problem?
Reactions: Lady01
