P1000 Cummins Pusher's Ride
I was looking for that cb power connector u said u used for your front center light bar I want something waterproof that carries 10 aww wire figure 168 watts thats like 14 amps
I picked mine up at Napa auto parts for around $5 apiece I'm sure online cheaper but the were 10awg. I told him CB radio power plug replacement and he found it immediately
dale5740
dale5740
886
417
mt airy md
View attachment 12582 View attachment 12566 View attachment 12571 View attachment 12580 View attachment 12567 View attachment 12565 View attachment 12562 View attachment 12579 View attachment 12572 View attachment 12573 View attachment 12576 View attachment 12576 View attachment 12585 View attachment 12581 Soooo....well it too me a bit but finally got done about three weeks ago but haven't had time to post because we've already out camping since January 29th and just finished our holy grail of pickups our '98 Cummins 12valve manual with only 375,000 miles (our 3rd 12v including our motorhome and our now loaner pickup) I do all of my own work I don't farm out anything (I'm the guy most people pay to do it) and we have the 1000, 3 quads,7 dirtbikes,5 sleds,two diesel pickups, motorhome, all to maintain and build between just after Xmas-February our only off season, so I've been busy. To start off with I know a lot of people followed some of my designs and ideas about dual battery choices, dedicated system with a battery separator led lighting choices and even backup camera instead of mirror. Well I've drastically upped the ante. This is the 8th rig I've gone through for this type purpose for ourselves and countless for others and it gets way bigger each time. This time I wanted everything just right,but most of all I wanted nothing to interfere with adding or taking off any and all accessories, everything needed to be separated with a plug so something as easy as taking a bumper off doesn't require cutting and splicing, several factory Honda car harness plugs were used,all lights stereo equipment must be able stay on through the removal of roof windows doors ect,adding anything doesn't effect anything at all, everything clearly marked is user friendly and lites up, nothing effects anything from the ultra dependable Honda base unit, is fully reliable and totally waterproof,NO VISIBLE WIRES to snag on make windshield or roof remove ability bad or look like crap, double fused and dedicated relays easy to reach and labeled, no inefficient pod lighting to snag branches or effect future accessories,even spread 360 degree lighting to guide the way at the right time and automated so anyone can use with no problems with dead battery or complications (lots of people come up with us and I'm not stingy)and above all no clutter dependable and fun that works as if Honda designed. No easy task. Hasn't really been done before from anything I've ever seen. We didn't just throw a light on with dangling wires to a switch on a nearly 20k vehicle. Absolutely nothing overlooked and no obstacle that wasn't eliminated. All mounting hardware was either built or replaced with stainless steel,including all bolts, aluminum,powdercoated. Everything is soldered,heat shrinked,water mud and dust proofed,separate colored wires(34 total and diagramed) loomed,placed out of any danger,extra mounts created, ect ect ect...you can shake this rig from anything added without possible movement. Any hole has grommets and very well secured from both sides. Since I made harnesses multiple wires were eliminated and a large common ground was made off second battery so each unit doesn't have its own that will fail and be impossible to find. I didn't purchase something because someone else said it works or it was cheap or easy. Lots of research over the last 3 months.We bought multiple units of lighting and ran wires all around and tested the 1000 multiple times camping (real world) with multiple people through all kinds of crap till it was right then stated over made complete harnesses bought the right lights and hid as much as possible including running harnesses through the roll cage. It's now done. A total of 12 separate interior light fixtures totaling over 70watts and 27 separate outside fixtures totaling over 1500watts, 13speakers totaling 700watts,onboard compressor, 110v inverter,multiple USB ports direct to the stereo with charging specifically for iPhones(1 each occupant) 4 separate adjustable zones for the speaker system and lightning(everyone treated equally) backup camera automatically turns on as well as side lights and rear lights when in reverse(also shows front low view basically at front tires in the technical areas) interior lighting,floor light,and outside entry light all come on in its own dedicated corner with its own door, the switch lighting comes on with driver front door. Redundant systems that can shut off certain high drain accessories in sequence of importance until power returns back to the second battery(which is totally separate from main)Lots of work! NOTHING SKIMPED!! Well here's how...easiest to start front work back...
Lights
---Center front upper bumper,
168w 5d optic Osram 12in 60deg/30deg provides center penetration low. Come on automatically in high beam also with separate switch,very bright easiest to install highly recommend!
---bumper upper corners x2, 50w 7in Phillips single row 60deg provides great center/side view and are tucked very close and just behind the bumper so no damage occurs wires run through bumper and unplug
---bumper lower corner x2, 15w Cree led cob stripes,multiple color white/amber 6in. These function as daytime running lights and are white while key is on. If main power switch is on (I'll explain later) They are amber. Also flash amber as a turn signal and are tucked very tight with 1/4 in lexan cover for brush.
---lower bumper cladding x2, 24w Osram 5d 60deg for extreme side view, will light up from front to the tire nothing escapes this perfect positioned light that's totally recessed and out of the way say goodbye to those pods next to the windshield.
---lower windshield, 700w Osram 50in 20deg/60deg double. This is the curved bar to fit the front perfectly, be as tight and low as possible, providing both maximum straight penetration as well as awesome side light(again no pods) and totally out of the way. It is mounted via 1/4 in stainless custom mounts to the roll cage with an additional hidden center support for a very solid mount. No wobbly windshield mount here. You can take the windshield totally out or install a 1/2 unit when it's hot and it's so low it's never in the way even w/o window. This is a high drain unit and is third in line to automatically shut off if 2nd battery power dips below 11.7v
---inner fender lights x8,2 9w 12deg Cree rock lights per corner automatically turn on in 4wd or separate switch and really light up undersides for extremely rough terrain. They also double as part of the party lights(I'll explain later) with multiple colors.
---lower side lights x4, 2 each side Cree 15w 120deg are mounted in between the doors and lower rear step these are great at giving you light right up to the very sides are highly recommended cheap and easy. Separate switched but will also come on automatically
in reverse and 4wd.
---Upper roof side mount x2, Cree multiple color 36w 120deg. These are the only lights that require unplugged if accessory roof is removed. They come on as with side lights, and are part of the party lights.
---rear mount whips x2,55w 4ft Gorilla lights (best from all we've seen very tough) very bright multiple color separate switch also part of the party lights. View attachment 12566
---rear mount backup lights x4, Cree 15w 120deg. These are mounted to lower and side roll cage for maximum lighting. The work very well with backup camera(if you look close you can see me taking pictures in the monitor in the rear view pic) don't blind people riding behind you,light up sides extremely well and flat ass look cool. Works well while loading and turns on automatically when tailgate is lowered, in reverse, or rear camera switch is activated. (We had a single 72w Cree prior and it was always too much or not enough and was always in the way or covered by the rear window. These are always uncovered and great.
---door lights, 5watt Cree Honda logo lights up a Honda logo on each door that's opened. More cool then anything but does avoid puddles in the dark.
---under dash/rear box lights x4, 1 in each corner lights up entry per door and come on automatically also with interior light switch.
---speaker bar outer lights x4, 5watt cree cob strips. Each side comes on with each door opened and also switch.
---speaker bar inner lights x4, 3watt Cree are independent of each other and are designed as personal lights. They are mounted directly over head and provide instant light for anyone.
---switch lighting x14, each switch has instructional light that comes on with headlights or at dark with driver door opened.
---interior lighting comes on with any door or tailgate open
---party lighting turns on whips,side lights,and rock lights. It has a remote can be any color,flash, sequence and also has music mode which will "dance" to the music throughput those systems. This is also 2nd in line to turn off automatically if 2nd battery drops below 11.8v.
View attachment 12540 View attachment 12541 View attachment 12542 View attachment 12543 View attachment 12544 View attachment 12545 View attachment 12546 View attachment 12547 View attachment 12548 View attachment 12549 View attachment 12550 View attachment 12551 View attachment 12552 View attachment 12553 View attachment 12554 View attachment 12555 View attachment 12556 View attachment 12557 View attachment 12558 View attachment 12559 View attachment 12560 View attachment 12561 View attachment 12574 View attachment 12577 View attachment 12583
what is the bright red or orange light to the left of your light switches on the left of the steering wheel in the pic your paddle is cutting it in half?
I use this as the power on. It turns on power to the lower power items without use of the key. So up camping people can use accessories that are only allowed including stereo and most lighting. Anything on this switch is ran from auxiliary battery,will not effect main,no possibly of little kids taking key or rig be stolen somehow if we pass out listening to the stereo. When this switch is on the white daytime running lights become Amber so we know it's on as well as the key off and removed. Keeps from burning up hours as well on the machine. We have excellent sound system and lighting on the outside of our bus but use this a lot without it or to help others setup camp or simply get wood and do chores. We put it there so you don't even need to open the door to Bluetooth in or turn lights on to see something. However simply opening a door lights up interior, ground lights and all switches.
can i see a pic of how u mounted the 50 in led light bar
I would suggest to anyone doing this to use a 52in and bend the mounts out a bit it would be easier. It would stick out a scoutch but way easier. It's so much more stable and better then windshield mount. Takes a bit of ingenuity but end result is better light tuck in in and closer really something you can be proud of your not just drilling four holes in an accessory that now can never come off make sure to use curved it's easier fits tighter because it doesn't have to be shimmed out from windshield and lays down way better lighting no need for pods to gab at branches and break. I simply used 3/16 stainless steel 3inch strip Cut to fit drilled three holes pretty easy. You have to get longer bolts and then I put one extra nut on before the bracket backwards and lockwashers and that's it. Don't go 700watt unless you plan on upgrading stator. I also did a center for the bar I like overkill. You could tow a vehicle out of a ditch with this led bar. You will have too bend the lower corners of the windshield in just a little so you can install the rear bolt/nut to give a little clearance. I'll take the best picture I can when I get back home of that and the center mount.
dale5740
dale5740
886
417
mt airy md
what the hell is wrong with you!!!!!! next question Do u have a cappuccino machine maybe a elevator that takes u to the roof for viewing the stars while on ride u can just turn on the auto pilot and drink a cap while the honda drives itself through the trails. U must have a thousand hours in this build!! Extremely nice!! GOOD JOB MAN
im not right in the head!! My physiologist is now paying me because her team failed so miserably. But you know how these things go. It's no where near done but it's at least ridable till I can start the next run of ideas but it's now riding season so it'll go slow. Thank you lots though.
Reactions: dale5740
dale5740
dale5740
886
417
mt airy md
so when the the key is on it adds hours to your pioneer and also effects the service intervals even if its not running?
dale5740
dale5740
886
417
mt airy md
Lights
in reverse and 4wd.
what company did u get your winch switch from?
dale5740
dale5740
886
417
mt airy md
click on jdm link above they have all sorts
Yes. I do all my own service and mileage doesn't really matter for warranty it's the yearly thing does but I still don't want to sell the vehicle with 1,000,000 Hours. Some nights it will sit there while we're using lights and stereo for 5-6 hours. It's easier to run a separate switch then busy hand can't get too busy as well
Reactions: dale5740
dale5740
dale5740
886
417
mt airy md
so when u reach 100 hours or 300 miles the wrench will come on witch ever comes first or miles only? I assume either one?
eBay. Even if things are a little more sometimes I always order from eBay the selection is huge and I love how they work and PayPal. That switch was 8.95 free shipping. I purchased this switch different lighting color from the rest because I wanted to make I obvious to anyone in the machine it was different but that was redundant I guess because I've got a master switch in the lockable glove box (has a combination lock for the knob) that turns off the winch,700w led bar,party lights,and inverter so no one unauthorized can get into trouble.
I assume so
Reactions: dale5740
dale5740
dale5740
886
417
mt airy md
dude you are sick!!! I don't give many compliments and try not to rub nuts lol but damn u really out did yourself!!
Thank you so much!!!! I just wanted it to be done right and we keep getting bigger every rig we do. We've been doing this for about 10 years and it gets easier all the time because of the availability of things. There is a group of Polaris' that we ride with about 3-4 times a year(that's about all they ride and ride in groups because well you don't want too many miles on a Polaris and have to ride in groups for dependability:)) but they have kind of followed our ideas over the years and I have to keep innovating. This year they won't be giveing me as much hell with 1000 over the 700
Reactions: dale5740
dale5740
dale5740
886
417
mt airy md
Lights
in reverse and 4wd.
just got my 168w 5d optic Osram 12in 60deg/30deg and tested it in my back yard and garage!! big disappointment, the center beam seams pretty good but the sides u can't tell are even on!!! with that having been said this is my first light bar? this is what it looks like on my garage wall. does this look right?
IMG 1404
just got my 168w 5d optic Osram 12in 60deg/30deg and tested it in my back yard and garage!! big disappointment, the center beam seams pretty good but the sides u can't tell are even on!!! with that having been said this is my first light bar? this is what it looks like on my garage wall. does this look right?View attachment 12959
Something is wrong!! Email seller right away that's not right. One hell of a spot beam. Are all lights lite up
Similar threads
