@Bones was gracious enough to send them a couple of weeks ago. He had the original version and his different design so I could choose the option that I like the best. I'm sure he will get you taken care off. There are some really great guys on this forum and we owe them all.Does anyone else have a copy that they can forward along?
You definitely deserved them. I'm sure it took you longer to draw up the skid plate then it did for me to make the bushings. Have a good day.And I was paid well with a set of kickass door bushings for my troubleDoors are tight as a drum.
On the way. good luck with it. Mine works well for the way I ride.
If you can send me a set as well I’d really appreciate it! [email protected].On the way. good luck with it. Mine works well for the way I ride.
I would really like to have a copy in any CAD format (DWG, DXF, DWT etc..). PDF will work also as long as its "to scale" when I print no scale to my plotter. I use Civil3D 2015 and Map 2014. If you could save back to 2013 or 2015 that would be great.
[email protected]
Thanks in advance
I just received the files. I can’t wait to check them out. Thank you very much sir.Just sent to all three of you guys. Good luck.
I've sent these dxf files to probably 25 people. Anyone actually use them?Just sent the files. Let me know how it turns out.
LmaoI've sent these dxf files to probably 25 people. Anyone actually use them?
No, I just have PBA. Or thumb Tourette’s.. not sure as the test results haven’t come it yet.Funny?
It is definitely on my list for the winter. Not many places I worry about around here, but came off a mountain hunting the other day and wish I had your plate underneath me. Just changed my oil today and I think I will definitely go with your 3 piece design. It should make changing the oil easier.I've sent these dxf files to probably 25 people. Anyone actually use them?
