P1000 Diy skid plates
I did it!!!!
0F66C7A1 53A5 45D3 8E21 81B1EAC09630
Firemedic530
Firemedic530
387
1,133
West Jefferson, Ohio
That looks great. I was liking the idea of a one piece, but the places in town with the plastic in stock didn't have 60"wide. I didn't have time to wait because I wanted it done for TO. I will see you soon to look at it in person. I'm hitting the road now.
Rincon
Rincon
79
109
Yuba City, North California.State Of Jefferson
Awesome job! As soon as I get some time.....................I'm going to do it! Anything, tips or tricks I should do from your installs? I really want to wrap around the sides towards the doors, and also want to try and incorporate something in the front wheel wells for sticks.
Reactions: BWAF
Are you going one piece or a three piece?
Reactions: Rincon and BWAF
Firemedic530
Firemedic530
387
1,133
I found that bending the 1/2" UHMW required a lot of heat and patience. When I tried to go too fast it would tear open and crack. That was my first piece. It still survived the TO, but looks bad and is weaker I'm sure. I used a torch to heat both sides of every bend until it was shiny and even burning a little. It worked ok, but then I switched to a plastic heat tube that my neighbor has for fabricating plastic. I had to let each piece sit for 15 minutes per side and then it bent like butter. My neighbor was supposed to bring home dies for his break and help me, but a family emergency prevented it. I used angle iron in the vice to hold for bending. I also found that it didn't like being reheated to try and adjust the bend. It would start cracking.
I routered all of the edges and countersunk the Honda washers 1/16" into the plastic. I also used 6mm nutzerts in the factory skids instead of self tapping screws.
BWAF
BWAF
I get paid to pass gas
8,864
42,478
Carthage MO
Really good skid plate I love mine
I jot the 1/2 trail armor skids hope to see them in a week or so will share pic when done!
CTDpower
CTDpower
341
807
Gypsum, Colorado
Hey JTW, did you use the template that i made? I've sent it out to like 100 people but have yet to hear back from anyone whether or not it worked out for them. Can't remember if I sent it to you or not, but I was just curious. It worked for me, but it'd be nice to hear from somebody else lol... Sweet deal on the one piece btw. I went ahead and did the 3 piece on mine since a 5x10 was double the price of a 4x8 sheet. I actually still haven't even done my two slider pieces (too lazy). Now that the main part is covered I said F it and moved on lol.
No.. I did mine before you came up with measurements. Mine were based of @Cuoutdoors
Reactions: Cuoutdoors and BWAF
clifforeilly
clifforeilly
WFOSXS.com
795
2,688
Goodhue MN
Hey Guys,
I'm debating about DIY or just purchase ?
What would I have for $ into it if DIY ? How much time ?
Which one would be your recommendation if I decide to purchase ?
If DIY is a $200 savings I'll probably just purchase. $500 savings and I may be more inclined to DIY ?
Reactions: dnjones161
Hey Guys,
Purchase, you will have a lot of time in DIY and unless you have a perfect pattern and a perfect cut on it the 1st time it’s not going to fit as well as Factory UTV or Trail Armor.
I did it myself because I wanted a one piece... I think I had $616 in the 5x10 sheet to my door.. and about another $100 in hardware. Plus a lot of time.
Doesn’t seem like a lot of savings, and isn’t really unless you compare apples to apples and to another one piece.
clifforeilly
clifforeilly
WFOSXS.com
795
2,688
Goodhue MN
I should add that I don't need a skid plate for 99% of the riding I do here in Minnesota . Getting ready for the takeover in April.
Reactions: JTW
