P1000 enclosed trailer
L
laudy
United States
I have a 2019 pioneer 1000-5 deluxe with honda hard top. Looking for a trailer. to all of you that have a trailer for the same ride. What size of trailer did you end up with and what was the door opening vertically.
thanks
laudy
Reactions: BWAF and Plumber32
thanks
laudy
factory you can get away with a 7’ height door opening which is 6” extra added to the trailer, if you start adding tires and lift you’ll need to measure the machine and add height accordingly.
An 8-8.5’ wide is going to be best unless you’re a spry youngster and can climb out the back of the machine.
I have a deposit on one at the moment myself.
66,120
I've got a 24' enclosed. The door opening is 78" with dovetail i run a 2.5" lift and 30" tires but chopped the cage 5". I rub just a touch. I think technically my trailer is 6'6" in height. You will want a 7' ceiling height.
Reactions: Vikes79
HondaRed16
HondaRed16
254
499
Arizona
Word of advice; if you have friends the ride get a 20’ so you can y’all two! Not to mention all the others it would be handy for, you have to store it somewhere either way so might as well go bigger
Reactions: Plumber32 and BWAF
17LE
17LE
80
207
Iowa
I have a Legend Trailmaster 8.5 x 26 enclosed. We use it to haul 4 sleds or 2 SxS
Very well built and tows great.
With the Hard Roof it adds a few inches, mine is factory ride height plus 2" for the difference in tire height and I have to have a 79" door opening
Reactions: BWAF
Vikes79
Vikes79
SKOL!
10,817
104,942
South Dakota
I have a 7x14 aluminum stealth enclosed double axel. Inside wall is 81” wide. Ceiling is very similar.
I’m pretty big guy and can get in and out of the Honda pioneer 1000 fairly easy, but the Pioneer must be all the way to one side of the trailer. If you go a bit wider it won’t hurt.
FDBD5DBE 4AFF 47C5 847F 901F2390EC68
I’m in the process of adapting it for ice fishing as well.
17LE
17LE
80
207
Iowa
Like a tent off the back ? or will the axles move ?
208,011
What year is the 8N?
Vikes79
Vikes79
SKOL!
10,817
104,942
South Dakota
Axels are remaining fixed. I have sleeves thru the floor.
insulated the roof, added power port, cable tv antenna access ( gotta watch football!) and tv for underwater camera and a heater. Very much the same to make it a living space for camping.
I used frp to hold up the foam insulation...wished I would have used something else as it wants to grow when it warms up. May end up changing it.
led lights for illumination. All electric on a deep cycle bat with a 500w inverter.
not quite done but here are some pics.
23D7C3BE 04AD 4523 841D EAA0D1BDFF1D
85EDB8E5 8DFB 4A67 AC3D 6ADA4626E5C0
8162A98C B3B6 4B35 B04D B020558E8BA2
BE20BF99 F793 43A9 8DF7 D3C005AC42F7
AC9FDA16 E3E7 4F84 A967 B871236EE9B6
Vikes79
Vikes79
SKOL!
10,817
104,942
South Dakota
actually it’s a Jubilee. It’s a project I’m working on with my nephews. It was stuck in two gears. The tranny is now unstuck but there’s a problem in the pumpkin that is next area of attack. Engine runs. Will fix rear soon and paint in spring for parades and acreage work.
The question you need to ask yourself is.. do you plan on keeping stock or not?
mine is an 8.5x24.. my door opening is 83.5 inches with the dovetail and 84” interior height. It’s an Intech brand.
8CA56201 7149 4D54 B078 4227B31481B2
B2B30D7E DA1B 40E4 ABB4 46AAF0F1AEEF
8B289CC4 75D9 4B22 98BC EC2A9E1D8BE9
C47020C3 E47E 434D B522 9FA32EFA7ED3
E
elkguide
3,377
7,963
Vermont
So @JTW, how do you end up doing everything on your side?
(or is that only when you're not upside down?)
TerryH
TerryH
664
2,241
Springdale, Ar
We have a Haulmark Transport 7x16 x 84 high. The rear door opening is 80". Works great for our Talon. I just step out onto the front tire and off the front. Pretty simple even for an old fat guy. I did a race trailer style interior build with cabinets, counter etc... I wired for 120v lights and plugs. We've been really happy with it.
49306677626 936b734b95 b
48882757968 9f5790d940 b
48275071437 d7e8b47464 b
48883475652 eeb7a6af13 b
This is where we started...
47981223678 e77a575971 b
Did you bust all the springs on your truck?
17LE
17LE
80
207
Iowa
View attachment 175465 View attachment 175466 View attachment 175467 View attachment 175468 View attachment 175469
Looks good !
