P1000 Finally found a bumper I like... Slasher Front Bumper
Well.. Almost done and ran into an issue. Seems the ONLY winch mount plate they make does not work well with wide spool winches ex. Terra 45. I am contacting them now to see if they have a solution.
F897806ac6e4ff4b71a7743fcdc22fa9
Rut roe...
popeye
popeye
3,273
14,642
kapowsin, Wa
Is your issue only with the aluminum fairlead? Or will the winch not bolt up? I had the same issue with mounting my viper 5k winch to the emp front bumper.
63,987
It's the line hole on the plate is not wide enough. It will cut into the line. A smaller fairlead will work but then u can't spool up the winch correctly.
Anyways. I'm chopping it up today for a dirty fix.
Reactions: Plumber32
popeye
popeye
3,273
14,642
kapowsin, Wa
That was my fix on mine
chadbo
chadbo
Mama tried
2,044
5,658
Seminary , Ms
Did you work this out?
Reactions: my99svt
misterkit
42
36
ny
This may be my next bumper
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,569
Greenville, Mo
63,987
A few pics that make me scratch my head and WTF.
I emailed Slasher and said... you mean to tell me you make a failed that will accept wide spool but find it acceptable to have the plate cut the rope.
Do you have one made correctly?
Short answer - Nope! And no plans to make one.
One reason I have been slacking to post.
I suggest just using the mounting plate that comes with most winches. But I had already ordered this and kinda like it better than the other.
Also, I found bumper is not made for a super winch. Slasher says only Warn bolt patterns.
I ended up spending a few hours with the grinder getting it fitted up correctly. End result is nice but damn, a lot of work for something so stupid.
20170313 152322 20170313 152314 20170313 152304 20170313 152238
my99svt
my99svt
I identify as a lesbian
1,267
5,248
Broken Arrow, Oklahoma
Hey @Hondasxs, after having it on for a while do you still think it was a good investment? I’ve been looking at them and will probably order one this week. I found it for $394 shipped.
Being I also have a super winch, are you saying I shouldn’t order their winch bracket? Any other info would be helpful. Thanks!
63,987
Yes, I love it. I like the bracket too. It's bigger then the one included with your winch. So, that's your choice. Just know its made for small spool and you will need to cut it out. Think I have to weld a price too. Also drill holes to center it all up best you can in both winch and bumper. It will not go perfect center but close enough you want notice it.
In say... Order it.
Reactions: my99svt and Eltobgi
207,989
In say... Order it.
What do they weigh?
7,143
27,177
I also have the Slasher bumper. I like it also, no winch on it yet.
20170821 193241
Reactions: Landman and my99svt
