P500 For Sale: Rubber Noise/Heat Shield
158,255
How long is the wait list currently @trigger? I have.buckets so the heat isn't much of a problem anymore, but noise is still a factor. Possibly worse now with less solid seat covering the bottom..pondering about one now after following this thread since it began...:D
Currently next day shipping unless you order on a weekend, then it'll go out Monday. I knocked out the wait list a while back and try to keep around 5 on hand.
Depending on what you've added to put in the buckets you may have to cut it to get it in there, but it'll still be better than without. Cut one of mine from the latches to the front when I added harnesses, still functioned fine.
Reactions: Shadesmn
158,255
Received my Trigger Shield in the mail today! It fit perfectly. It stops almost all the heat into the cab and cuts the noise to a tolerable level. Great work Trigger, I highly recommend the shield to all P500 owners.
Yeah I don't think there's anything you can do to totally eliminate it but like you said, it makes it tolerable. Glad to hear about the fit, that's always my concern. :)
158,255
@trigger
Got the Trigger Shield installed this weekend. Perfect fit and I highly recommend. I haven't driven far enough to get the temps up, but I was happy with the noise reduction.
Thanks again
My pleasure man and glad it was a good fit! What's funny is I was looking through my list and AR is by far the state that I've sent the most to. Must get hot as hell there?
hawgsooie
hawgsooie
12
20
AR
We have our days for sure.
twodog
Ozark Mountains
Yep it sure does. It won't be long now either.
I just got back from my first ride of any distance since installing the trigger shield. It is noticeably quieter and a lot less heat and dust. It was cool enough today a little more heat would have felt good but all in all a way better ride with the shield installed. We put about 30 miles in the 500 which is about what we usually do. Us old folks are not into marathon rides or heavy duty off road stuff.
11,348
84,458
Thats some good rubber, used a small trim piece to pad an accessory mount on the ROPS and to pad the Chooglin glove box. Keeping some pieces in the tool box for future uses.
Yep, the product is great, the installation is the weak link (speaking for the original use of roofing that is) I’ve had it installed on two commercial buildings and ten years is all either roofing company would give. Not sure if it’s because of seams and flashings or what....
158,255
Yeah that's all Firestone will give is ten years. There's a company here in MI called Duralast, supposed to be the best roof you can buy. It's more of a PVC than rubber though. Expensive as hell too.
Stays flat and tight around roof jacks and flashings? Are they offering more than ten years? Of course it’s hard to get more than ten years on any flat roof, but both of mine had about 2-3’ of slope in 80’ and they still wouldn’t go more than ten years....shrug.
158,255
Yeah you have to use their products for any roof penetration, witches hats, pitch pockets, vent stacks are custom made for the size pipe...
Ok cool, what warranty if you use that system? And ball park me on a price per square for flat/flatfish roofs. I’m interested to see if it’s cost prohibitive. One of my buildings literally had no roof penetrations, and still 10 years. :rolleyes:
What about chimney crickets. :D:D:D:D
twodog
Ozark Mountains
I went to the dentist today and the hygienist there she and her husband ride a lot in Polaris machines. I was telling her about the Trigger shield. She was ready to buy two then until I gave her the bad news about them only for the P500. She told me that if you ever make them for the RAZR and the Ranger she will buy two immediately.
Arkansas from mid June to October can be a hot dry dusty place. may be why so many here want the shield.
Wallace
Wallace
Well that didn't go as planned
2,812
15,093
Lonoke Arkansas
Wow just got around to pulling mine out of the box. Check out these detailed instructions.
15537203131328334498790268038222
