P500 For Sale: Rubber Noise/Heat Shield
195,195
Hey Trigger,
Installed it today and it fit great! You are a genius! I had to make the areas on top where the seat clips in a little wider but everything else lined up perfectly. As I said before, you should sell these on eBay. You saved me loads of time and effort. Thanks again! I tried to add some pictures below....
View attachment 122033 View attachment 122034
Glad you like it Jonsey! Funny that you had to make them wider, I actually tried just doing little holes for the pegs to poke through on one of the early ones but it just didn't sag right. Trying to keep it tight in that area to form a seal but I guess doing a little adjusting is better than having a gaping hole. Report back on the performance once you've given it a proper test and thank you. :)
Mudder
Mudder
NTC/TAP Transition Member
11,865
90,391
Like the way it comes, easy to trim with scissors for custom cuts. Warm days here and shield coming into its glory. Used a scrap piece to make a rubber gasket for water hose. Thanks. @trigger.
195,195
Had I known you had uses for scrap pieces, I could have sent you a bunch!
fp4
fp4
6
9
Western Colorado
Well it's been awhile since i got the shield but I finally put it in. Took the 500 for my first ride and it worked great. I didn't notice any heat coming up from the seat and the noise seemed lower than without it. Now I just have to figure out what the 500 is capable of doing since I almost always ride alone.
Thanks Trigger!
195,195
Reactions: Chooglin
Chooglin
Just a little something I added to the Trigger shield , not that it needed it , everything fits and works fine without these!!!!
I took a few pieces of thin wall drain pipe and removed a section out of it , so I could use them as clamps , to secure the rubber that folds over the cross bar in the back. I didn't want to zip tie them so I came up with this idea........ I made up 4 of these!
20190420 181925 20190420 184325
195,195
View attachment 124400 View attachment 124401
Now that's a great idea! Mine just friction fits under the box back there but that pipe gives it a more finished look. I might be doing that, what size pipe 1.5"? Paint them black!
Chooglin
The inside dia. Of the pipe was 1.375 and is thin wall pipe for a bathroom sink drain! Definitely painting them black or may go buy some pipe that is black already.
That’s a great idea. When you say get it in black, do you mean ABS?
Reactions: SouthwestORV
Whatever I can find that is black and thin wall.........ABS , PVC......
I’ve only seen ABS in black, it’s used in mobile homes and RV’s, but it’s typically more brittle than PVC. I think you’ve got a great idea, just spray those pieces you’ve already made black, IMO.
SouthwestORV
SouthwestORV
744
1,731
Taylor, Arizona
You going to start selling them? The Trigger Shield ought to come with them...so you sell them to Trigger. He sells the whole kit to us peasants!
Mudder
Mudder
11,865
90,391
Good tip clipping using sink drain pipe, wondering if something like splitting a hose would work also. Will check the garage for leftover plumbing supplies. Thanks.
SouthwestORV
SouthwestORV
744
1,731
Taylor, Arizona
Good tip clipping using sink drain pipe, wondering if something like split hose would work also. Will check the garage for leftover plumbing supplies. Thanks.
I'll bet split hose would work too.
