P1000 Harness bar
Scuba0331
Thank you for all that replied with some great ideas! We recently had a Fab shop open up in my town and the guys there do a ton of off-roading with their kids. I'm sure they can add to the solutions already offered. Thank you!
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
Has anybody run a center Harness that would be used for a kid?
I dont think this would work for a small child. I think you would have to add a headrest to this bar to keep a small passenger from hitting there head. If your talking forward facing carseat, this would be a great spot to tether the top of the seat.
So far I have kept the Seat belt for the middle and the passenger side since my 8 year old sits in both spots (depending on if wife is riding along) I have taken a pool noodle, split it and I wrap the Harness bar with it above him & he will wear a helmet. I do want to look into a harness that will fit him.
Moses
Moses
Owner - Brick City Fab
199
471
Gilbert arizona
Thank you guys for all of the feed back! We will be providing a 12" Piece of foam pipe insulation that will fit the diameter of the tube on the harness bars for the center seat. That way youll have the option of using it to pad the center section. The Driver and Passenger side of the bar doesn't stick out passed the back or head rest.
39,079
Why not make a center headrest mount that is lower an option for buyers?
7,139
27,139
Good for you Moses!
Reactions: Eltobgi and BWAF
Moses
Moses
199
471
Gilbert arizona
READY FOR POWDER COAT! :)
IMG 1438
13,349
64,937
Yes Its BCF-10- at check out for 10% Off
@Moses, Can you look into supplying longer hardware holding the clamps together? Maybe switch from SS to zinc plated steel?
I barely had a single thread engagement when I installed mine. I swapped the 8 screws out for 1/4"-20x3/4" zinc plated socket head cap screws. I was not comfortable using the screws supplied.
Reactions: sharp
Moses
Moses
199
471
Gilbert arizona
will do thanks for the feedback!
Reactions: sharp and JTW
