Ok , so Wednesday evening my son got on his P500 ( it had been sitting for about 2 months) rode it the yard for about 10mins and it died and wouldn't start up.. I drained all the gas out of it even though nothing but non ethanol fuel has ever been run through it and put fresh fuel in still wouldn't crank. I changed spark plug and put sea foam in it and after it sits for a while it will crank and idle for about 10secs then dies, it will do this for about 4 times then it wont even crank anymore, one time it took the throttle for about 1 min then died and wouldn't crank back up... You can hear the fuel pump turn on when you turn the key... when it does crank it act like an old bike with a carb and just wont' take gas... I sprayed some sea foam straight into air box and will run as long spray but thats it ... what to check next..I dont know much about EFI
