Ok.. so I was up all night trying to get things wrapped up on my build before this weekend... So my mind isn't working very efficiently right now... here's the deal. I have a dual battery setup with the bussman relay prewired fuse panel like many have bought. 5 relays and fuses and 5 hot fused circuits. I'm running 5 pin switches. And I want to run a voltmeter for each battery. The little digital leds voltmeters only have a positive and negative which means if hooked directly to the battery like I had original thought I would do.. won't they remain on all the time? So how did you guys they have ran a dual setup with two meters, wire them? Will I need them on a switch or is there another way I'm not considering?
Second.. let's say we're wiring a light on a relayed out put on our bussman box, does the trigger wire go to lower left switch post 3? And the larger relayed feed wires go to the actual light? What about the center post 2 on the switch, what now feeds it? Sorry, but relays are not making sense to me this morning.. thanks for the help!
