P1000 Installed satv winch today
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
Installed the 6000lbs super atv winch tonight wasn’t to bad but I am curious when using a snatch block what dose everyone hook to on the buggy cause I have no where but bumper looking for ideas
2A36A58A 60DB 4AAC 8773 32FAEC2D7566 F585C161 79BB 4FFE 809E F3F89C508F2F EAABC21A FD0E 4668 8654 34982044FE3B 87B6E315 4118 4AE5 9240 981C38D943CD 6508BA54 9FE3 45FC 99B3 E7D15EE8A06B 02A45720 962F 4A48 AC46 52DBAB9ADC40 95A26367 CAFD 4613 A1BE 2B7AB97BE8AD 48C70BE9 8766 4290 8C94 52674F368AB7 83961695 22E4 457D 8F30 4FB590F1A57F FB8F373F EC4F 4754 AE9A F363E16C8278
Tie
Tie
35
109
Toronto
View attachment 348406 View attachment 348407 View attachment 348408 View attachment 348409 View attachment 348410 View attachment 348411 View attachment 348412 View attachment 348413 View attachment 348414 View attachment 348415
Here are a couple options I have been looking at for potentially attaching to the flat part of the bumper. One is to be welded on, one bolted on, and one has the option of either/or both. They are listing them on Amazon as "clevis mount".
I would welcome anyone's comments on this idea...
NorthernJoe
NorthernJoe
325
1,248
Northern Ontario
I went to Princess Auto and got some eyebolts, attached the through the bumper to a piece of angle iron which is welded to the frame mount. You can bolt or weld the angle to the frame mount. You could also use a larger eyebolt
IMG 8918IMG 8917
Bighat
Bighat
875
3,736
Gallipolis Ohio
Your winch is only as good as it's weakest link. Pulling a stuck vehicle that is in deep mud and/or on and incline can add as much as three times or more of force required to move the vehicle. Winch rope is totally under rated that ships with almost all winches. If you want the best go the Masterpull, but the they're not cheap. And don't buy anything made in China.
bumperm
bumperm
1,848
6,646
Gardnerville, NV
Couple of points. There's a general rule for sizing winches, that is 1.5 times the vehicle gross weight . . . I've also heard 2 times. The Honda installed winch, that came on my '21 SE is a Warn 4500, the vehicle weighs just under 2000 lbs. Last week I used my P1000 to pull my tractor out of the mud, and at a 25 degree uphill to boot. The tractor weighs about 3000 lbs. I used a snatch block at the tractor tow bar and ran the winch line back to a shackle mounted to the front bumper which bolts through the thin bumper and a thick doubler - they are doubtless the weakest link, though I mounted the shackles right next to where the bumper's frame mount brackets are welded. I had the back of the Honda strapped to the trunk of a large Jeffrey pine just uphill or it would have simply pulled the Honda down to the tractor! Something was going to give, I thought, so paused several times as I added load. I watched those bumber shackles closely and all was fine as the little Honda yanked the tractor slowly out of the mud!
The limiting factor with using a winch that is larger still, is one of available electrical power. My 4.5K winch can draw something like 252 amps at full load - over 30 amps while reeling in a slack line. I have a second battery, but even that and engine running, an over 200 amp load is gonna decimate the available voltage very quickly. When that happens, guess what . . . I no longer have a winch that is pulling at it's rated power. That will happen even faster when running a 6,000 winch that can draw up to 328 amps or so. Bottom line, bigger sounds better, but without lots of battery capacity, it may not be what it seems. (Note too, the max 50 amp alternator capacity is only available at something like 5,000 rpm, not with engine at idle.)
20211017 112959
Bighat
Bighat
875
3,736
Gallipolis Ohio
I haven't proof test mine on anything but trees and logs but I can tell you that it pulls the battery down quick, watching my voltmeter. And, it can take a while to charge back up. If I was really stuck it may take a while to get out if I didn't want to kill my battery.
bumperm
bumperm
1,848
6,646
Gardnerville, NV
Are you talking about using a snatch block to loop your line and get more pull?
That 6k winch would dangle your machine from a tree.
That would be my understanding. They come in two basic flavors, the old fashioned metal ones and the newer "soft shackle" and "recovery ring". The latter work surprisingly well and are much lighter to pack around.
