P1000 Jackal's P1000-5
F
Fullthrottle
164
84
Take that windshield off it will get to top speed.lol Glad you still like it.i haven't gotten mine yet local dealer doesn't have one right now but I'm thinking April mabye sooner.
Tabascojunkie
Tabascojunkie
84
50
SE Louisiana
I would say speedometer will be way off.
Speedo is definitely off. This morning ran with GPS to measure top end. Running north-south with a 5-10kt N wind made two passes. SB run 61.3 and 61 mph and NB runs 59.4 and 58.8 mph. Speedo was 3-5 mph off. I realize this is a rough estimate of speedo discrepancy but 60 mph driving solo and holding and reading a GPS was ...well, a pretty full workload. Just giving some numbers for the engineers out there to chew on.
I'm satisfied regardless
Reactions: pct
amc019
amc019
480
592
Little Rock, Ar
This makes me strongly believe the speedo is inaccurate from the factory on stock tires.
F
Fullthrottle
164
84
Big question is did you experience and kind of issues at wot tapped out in six gear with cutting out?
280,135
I think it will be OK got some good contacts with RMATV (where I got them) I believe they are going to swap me out with what I need no problems. Dropping to 28x10x14's they are only 2 lbs. heavier (37 lbs. ea.) than OEM rear tires and a full 2.7" taller at 28.3". This will solve my rubbing issue without spending $500 on forward A-arms.
Everything is working out RMATV is taking the mounted tire and wheel set back, sent me shipping labels and all and replacing them with 28x10x14 Roctane XD tires on STI HD3 rims with 6+1" offset and refunding me the difference in the tires sizes. I knew I loved them for a reason, first time I ever had to return anything let alone a nearly 160 lbs. set of 4 tires and wheels.
Hometeam
Hometeam
1,023
4,321
Normal, IL
Company's like that are priceless!! I will definitely use them for future purchases!
jguillot
jguillot
58
32
Could I get away with using my 28" Mega Mahem's off of my rancher 420?
280,135
@jguillot Welcome to the club! I could not find the exact tire specs on the ITP website but, If you are running the 28x9 on the front and the 28x11 on the rear most definitely. Just to be safe I would recommend getting the Strong Made 2" lift it cost $162 I have several photos of it including install earlier in this thread. The 28x9 on front may only rub if taking a hard hit compressing the suspension considerably. Anything wider than 9" on OEM rims probably need the lift kit.
jguillot
jguillot
58
32
@Jackel Thanks bud, I have 9" all the way around. I forgot the wheels are wider in the rear. Is it true the lift voids certain warranty?
280,135
Well I'm sure the dealer will have to tell you yes but the way the strong made mounts at the bottom I do not see what could fail and it only take an hour to put on or take off. Realistically unless the warranty involved the A-arms and or shocks it should not be a factor in the repair.
280,135
If you have a pioneer 1000-5 I would almost guarantee the 9" wide tire is NOT heavy enough for the rear, I may be wrong but going from a 500 lbs. rancher 420 with 28HP to a 1700 lbs. SXS with 72 HP would be on the outer limits of reliability, I would hate for you to roll a rear tire off and tear up the machine or yourself. Be sure each tire has a load capacity rating of at least 800 lbs. each, if they do you should be good total GVWR of a P1K5D is 3350 lbs.
Reactions: lee and joeymt33
F
Fullthrottle
164
84
Wheels will get banged up too running a narrow tire in ruts or whatever.I don't even like 9 inch on front.
Bwaller872
Bwaller872
9
I just bought a new p1000 last weekend and have a set of outlaw 2s laying around the shop. Will they fit a stock p1000 or do I need a lift kit?
280,135
What size are they?
280,135
29.5 I should have put that on there the first time
I am not sure they will clear even with a lift. The 27" Bighorn tires Honda has on the Pioneer 1000 are only 25.5" tall with 14 psi in them. I have the strong made 2" lift and the 28.4" Roctane tires I will be using will barely clear under all conditions.
Bwaller872
Bwaller872
9
ok thanks for your help
