jasond
I picked up my R on Saturday morning and immediately got a few accessories on it. I'll put a complete list in this post and update as I go. I also have a YouTube channel and will be uploading videos after I edit them. Link is in my signature.
Initial thoughts: Quality/fit/finish is top notch. I'm coming from a 2017 RZR XP1K and where I'm used to self-tapping screws there's a nut and bolt with a rubber isolating washer to keep things quiet. In the 20ish backroad miles I rode I'll say the power is on par with my XP1K, but MUCH torque-ier (not a bad thing). With this being a Honda, I'm hoping/expecting to not have to fool with the repetitive maintenance items that require way too frequent of attention with RZRs (wheel bearings, bushings, u-joints, carrier bearing). I did remove the annoying door nets within 5 minutes of getting it home.
Accessory List:
Accessory List:
- Honda OEM Lower Door Inserts
- Honda OEM Lower Door Storage Bags
- Honda OEM Trailing Arm Guards (I thought these were a must with the way the trailing arm mounts to the bottom of the knuckle to try and save the powder/arm)
- EMP Full Front Vented Windshield
- EMP Rear Vented Windshield
- PRP SB4.2 Harnesses and HondaSXS seatbelt bypass
- Waterproof Fuse Relay Box for all electrical accessories
- Rockblockz Fender Flares
- 41" Light Bar with RokBlokz light bar mounts
- JL Audio MX600.3 amp, Rockford Fosgate PMX-2 Head Unit with PBR Products mounting plate, Rockville 8" tower speakers, and JL Audio 10" subwoofer in custom enclosure in bed.
- AED Off-Road Fabrication Accessory/Tower Speaker Cage Bar
- TYT-8600 Two Way Radio (transplanting from XP1K)
- 32" Maxxis Carnivores on System 3 SB-4 Beadlocks (6+1 offset with 1.5" SATV spacers in the rear to measure 71.5" front and rear)
- 30" Dual Animated Booger Whips
- Dual LED reverse light pods
- Rock Lights
- 4500 lb SuperATV Winch
- Honda OEM Front & Rear Bumpers
- L&W Fab Winch Mount
- L&W Fab High Clearance Billet Radius Rods
- L&W Fab High Clearance Lower A-arms
- L&W Fab Billet tie rods
- AED Off-Road Fabrication Tree Kickers
- CA Technologies Shift Gate
- 6-switch panel for lower cubby hole from Rick Bentley Customs
- Honda OEM Rear Cargo Bag
- Factory UTV 3/8" Skid Plate
- PRP GT3 Suspension Seats
- JEI Off-Road Bed Extender
- Honda OEM Upper Canvas Doors/Enclosure
- Inferno Heater from UPI
- Lifetime Trail Maps with Samsung Galaxy Tab Active2 (I use RAM mounts)
- HondaSxS Reverse Light trigger harness with 7" rear LED light bar
- Odyssey PC925L Secondary Battery with True UTV-SBI-CK isolator kit
