I have a brand new 2022 500 and the first two trips in the field the transmission locks in 1st gear and will not shift out. When I first start the engine and take off the engine stall’s several times and the transmission locks. The indicator flashes 1. I can turn the engine off and immediately restart it and everything works fine then I take off again and the same thing happens. If I take off real slow it doesn’t seem to have a problem. The transmission has shifted hard since I bought it but I’ve read that it will get better with use.
