P1000 Next P1K project begins
Eltobgi
Eltobgi
4,599
15,187
North Dakota
It's been hard to start since summer. Feels like tight valves but they are in spec. It's weird. Plenty of juice. And I agree with Honda car factory batts! Funny. We have Yamaha sleds they're the most dependable just because Honda doesn't build one.
Perhaps low fuel pressureo_O
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Is it FI? If so could be fpr bleeding down while parked. Turn key on for sec, turn off. Turn on for a sec, turn off. Repeat that bout 4 times and see if it starts better. If it does, you got an Oring bad on your fpr.
Reactions: Eltobgi
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
That is if it's designed like every other fpr on the planet. Knowing popo it probably isn't.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
If it has a shrader valve on the line, you can borrow pressure tester from auto parts store for free.
Reactions: moparornocar
moparornocar
moparornocar
RIP....Rocmar...
4,606
12,493
Augusta, Wisconsin
Mine was worried about wheel bearing grease on the carpet. Lots of cardboard protected from that.
moparornocar
moparornocar
RIP....Rocmar...
4,606
12,493
Augusta, Wisconsin
The shock took a sec to figure out. You build the door then take hanging fish scale at the top shock mount point to weight the door after mounted to figure weight. Ok 31 pounds. (Actually 6.5 but it's heavier closer to the hinges because of lever action) I used 35 works great. You use extension mount on door and that uses shock to pull door in when shut. Built mount on factory bolt spot works great. A couple braces were added also can never be too solid. It's coming! Look at shock I made sure to use one with defroster wire clips, I'll be adding exterior lighting on the doors to make up for the tinted windows. View attachment 28662
Done for the night I need a beer or five!
Your killing me smalls. I gotta build this.
Done with the Xmas parties. Pioneer time! Routered the holes out for the windows so they sit flush and are more aesthetically appealing. Gunna make paint today. A little bit of bodywork because I want these nice I guess call it the car guy in me. 30 years of paint and bodywork and I'm working with a sxs not sure if good or bad but I can't let things go
IMG 7670
IMG 7671
Came back and used two-part urethane on the joints. That makes sure there aren't any voids between the two and helps with strength. I think it looks a lot better when done. If tape is used prior it will look even better. Df479aeb78b658eb8f4b8f155cb67090F039873c84e465082dcb4766092173a4
1d89bd4ad1365b28519dd21a91357179E94ab4dffd207bcbf1338ef47b73ba96
Prime time. Wasn't going to finish there's super good but might as well look good before they get torn up lol
Ran out of wire for the welder but keep going. Used two-part to fill the hole that came on the hinges it'll work just fine. Cut them down and made them more appealing as well. 70773adbdb260f832bcbc6f5ca8e61b1
IMG 7681
I am very excited to see it all finished and put together. Man CP you are an artist
They should be on tonight! Might be a late one.
Everything squirted. I'm using GM paint code wa8624 matches fairly well. I could tint everything around so it matches Honda oem better but there's a lot of paint work to do and just not going to tint every time. Anyways I know the owner he my be a prick but he lets me slide sometimes lol
Tigermark
Tigermark
Outside looking in.
Damn CP, you been busting ass. Looking great sir!
Reactions: CumminsPusher
Thank you guys it means a lot coming from the great people here! Just got to get it finished before the Xmas weekend. That was my agreement with my wife.
Reactions: Tigermark and sharp
Tigermark
Tigermark
Outside looking in.
Can't wait to see the action photos of your Christmas Ride. That new cab is going to be awesome for you guys ! 4 season riding!
I've got green light on tracks for next winter then it'll truly be all season. That's why I'm camoing it out is for the sno!
