P1000 Next P1K project begins
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Looks like it will be more than enough material for both doors! Love that the whole family is involved in this project! :)
I'm guessing that you are kicked back in a folding chair with a cold one while the family gets er done:confused: lol
Can't wait to see finished project!
320,530
IMG 7218
No I was doing this:) notice the window recess. I x-ed previous and built these.
IMG 7217
320,530
Looking good!
Thank you Eltobgi! I may black out the center post but the lexan I currently have is bronze so I don't want that clash. Looks different it's going to take a bit to get use to it.
320,530
Sure be cheaper!
Reactions: Smitty335 and pct
Eltobgi
Eltobgi
4,599
15,186
North Dakota
I'll tell you what will not take a bit to get used to...an enclosed custom one of a kind cab during freezing northern temps! If you don't like the bronze look there is always window film!
320,530
I really want clear I think for the sides. The front one will be 1/8 tempered when I can. It will be nice to have an enclosed cab again though. Once these are done I'll start designing the rear it'll go better because I at least have a path now
moparornocar
moparornocar
RIP....Rocmar...
4,607
12,501
Augusta, Wisconsin
Sweet mother of Christ. That is gorgeous. I was thinking of just making a whole door since the factory doors don't seal at all anyway. I was thinking thin gauge square tubing or solid 3/8 plywood glassed over. Care to divulge materials used?
Eltobgi
Eltobgi
4,599
15,186
North Dakota
I hear there is a storm rolling through. It's supposed to drop up to 5" on us by the end of the week! I'm looking forward to it! I'll throw on my winter gear and take the Beast out to play in the snow for the first time;)
320,530
Good call! 23/32 pine plywood is what I started with this time around. It was 11 layers so it was super dense. Then glass over. The reason I changed up is that I wanted the windows to sit flush on the door so nothing catches. The upper doors sit in the center of the ROPS so they'll take less abuse. When I tried to get the glassed foam to recess for it things got bad quick. There wasn't enough lip for strength for windows to sit on the back egde. The wing windows operating would have gotten tricky as well. There is some more weight but the glass didn't need to be as thick either so it's only about 3lbs/side more. It'll be easier for someone else to build and the uppers won't require bracing glassed inside to mount to. Not excited to use wood but it's encased so it'll stay good.
I tried many things but for strength and lightweight this seemed to be the best. I was close to going aluminum full doors at the end but still wanted them to separate. I've measured all gaps around the door and have a pretty good selection of seals straight from eBay. The whole door will seal good
320,530
The hills around us have been white I'm pissed. Less camping for us
moparornocar
moparornocar
RIP....Rocmar...
4,607
12,501
Augusta, Wisconsin
I like it. I like working with wood, it's easier to manipulate and make to what you want. I wouldn't worry too much on the weight. Another 100 lb wouldn't matter when you've already got 7 people in it as it is lol
320,530
Well I don't like weight up high for sure and and the current hinges will only take so much but will take this I'm thinking.
I've only got the rear mount done that was pretty easy I basically put a longer bolt in the upper back outer cladding piece and a nutsert on on top and built a bracket. The front isn't completed yet but I built a bracket for the inside of the door. I'll update with pictures once completed
