I'm hoping to get some help. This is the 1st issue I've had with my 16' P1K5.
Engine-2600 miles
Rig- 4800 miles
All stock trail machine
Please read all.
After a rest stop i started back up, put it in gear and it revved without engaging. Back to park and then to "H" and it went just fine. After a few 100yards the gear indicator flashed with a dash and within a few seconds showed "gear 1 or gear 2" (whichever it was in) and stayed there. It wouldn't down or up shift but did not slip in gear at all. Manuel/sport/paddle shifts wouldn't function and then the oil light came on. I put 1.5qts of oil in it between the dct and engine. Both the dipstick read just over the full line but it still wouldn't shift. The oil light would come on sporadically and if i turned it off and back on it would shift for a few hundred feet and get stuck in gear again. (Clutches where grabbing, wasn't slipping at all) drove 1mile on flat trail to a road.
At that point I did the emergency pressure relief valve but I think I did it wrong as I didn't screw in the bolt all the way. I just pushed the plunger in and set it back up as it was. It made it a few hundred feet and the oil light came back on so I turned it off and back on. The oil light is off (it has plenty of oil) but it won't engage in any gear. I spent many hours reading threads and posts but haven't come up with a starting point besides checking grounds. What should I look into?
Engine-2600 miles
Rig- 4800 miles
Please read all.
