Oil change suggestions
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
Looking for a ideas for oil change kits this will be the second one buggy has 980 miles on it now I think what’s the best oil how much do I need I don’t wanna pay dealer prices any help is appreciated thanks in advance
21 pioneer 1000-5 LE
Reactions: Biteme
NTCPrezJB
NTCPrezJB
President of #NTC
104,750
935,066
Canton, OH
The best oil is the one you have on hand that is wet clutch compliant. But asking the question will get you some entertaining opinions so I’m going to grab my popcorn and watch!
113,192
All you need to know about how to and what u need. Asking what oil is best on here is like asking whats the best ketchup or Peanut butter to buy 😂 FYI if u must know, ive used Rotella T6 5-40 in my rigs since 16’ no issues.
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
Great thanks for all the info guys one more question do you use the same oil for the engine and sun transmission?
HBarlow
HBarlow
1,614
6,002
Daniels, WV
If you're a skilled mechanic please ignore my caution. But if you're not, be careful when you drain the engine and sub-transmission.
You apparently already know since you asked what oil to use in the sub-transmission - the engine and sub-transmission must each be refilled. Some sub-transmissions have been drained but not refilled.
Reactions: Biteme and TripleB
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
Thanks Yes I know there are 2 fill spots one for engine under rear floor board and sub trans under front seat I think but what I’m confused about is weather it’s ok to use the same oil that you use for engine or should I use something different trying to find a manual on it as I did not get one
Reactions: Biteme
HBarlow
HBarlow
1,614
6,002
Daniels, WV
Yes, you can use Honda brand oil or any that meets the same oil specifications listed on a Honda oil bottle. Using motor oil with the correct specs is important because of the "wet clutches."
Reactions: Biteme
P1K5Dave
P1K5Dave
2,203
8,278
Petoskey, MI
...what I’m confused about is weather it’s ok to use the same oil that you use for engine or should I use something different trying to find a manual on it as I did not get one
The most important spec is the engine oil because it's shared with your DCT. It requires an oil that is wet clutch compatible. (Marked MA)
The subtrans can use pretty much any engine oil.
So yes, the oil specified for the engine/dct is also OK in the subtrans, but what you *can* use in the subtrans isn't necessarily OK to use in the engine /DCT.
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
BTW, you can get a copy of your owners manual here: Keep it on your phone and it's always available on the trail.
Awesome I will save it now thanks I ordered the GN4 10w-30 pro Honda oil for my engine I will use that in the trans as well I also ordered some valvoline 80w-90 high performance gear oil for my diffs just waiting on all of it to come in
113,192
Or better yet, become a Life/supporting memeber of the forum and have accsess to that and more manuals
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
So just pulled my sub trans dip stick and there is a white fluid on the end is that normal
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
Any body know how this could have happened and how can I prevent it from happening again
324C55D6 F165 48EB AAAE A74ECE43B25D
