P1000 Oil Leak
207,989
Started smelling burnt oil a year ago, it would come and go and progressively got worse. Bad O ring on the starter was leaking oil.
IMG 3456
207,989
So.. You get it replaced?f nowhere
Yep good to go, to Tackett Creek! This guy is good $ 75.00 an hour verses $ 130.00 at the Honda dealer ship. Out in the middle of nowhere, takes me 10 minutes longer to get it to his shop than the dealership, lot's better drive than through town, all he does is work on SxS"s. Guess I almost live in the middle of no where, I love it!
207,989
Well the soga goes on, while at the TO had to add oil on a ride, had oil all over the back of the engine and was idling at 2,200-2,800 RPM and the engine light comes on, oil level is fine. the high idle RPM has been coming and going for over a year now. Now at home I can't get it to duplicate the oil leak? Honda and I are fixing to separate ways, I have 4,000 miles on mine?
TripleB
TripleB
11,932
101,130
Caryville, Tennessee
You need a turbo s.
bumperm
bumperm
1,851
6,656
Gardnerville, NV
If you're interested in chasing down that oil leak, fluorescent dye can be useful. It's made for tracking leaks in various fluids, with a version for motor oil sold at auto parts places. The oil fluoresces under UV light, a good UV LED flashlight works well for that, (as well as looking for scorpions etc).
To use, add the dye to oil, run the engine for just a few minutes and check with UV light (checking in the dark is best) If no sign of leakage, run it longer and check again. Detecting the leak early will help pinpoint the source . . . checking after a ride will have the oil spread over a wider area and make it difficult or impossible to tell exactly where it's coming from.
207,989
Thank you! Didn't know about that.
Reactions: Mudwing and Lady01
