P1000 P1K Shocks vs P1K5 Shocks
Gunslingertom
Gunslingertom
104
171
SW Missouri Ozarks
Anyone know what the difference is between the P1K front shocks and the P1K5 front shocks? They have different part numbers. I'm guessing the P1K5 is stiffer. I'm going to swap P1K shocks to my 700 and those are my options. Actually, I bought both, so I need to figure out what position to put them in. TIA
Reactions: Russ989
Russ989
Russ989
22,573
146,573
I would have thought the fronts were the same.. it’s the rear shock that are different.
Reactions: Russ989
Russ989
Russ989
22,573
146,573
I have seen all that and have purchased the sleeves from RB3. But as said, the part numbers for the P1K and the P1K5 front shocks is different, so I'm assuming it's the spring rate.
I don’t remember for sure but I think it’s the spring rate. I ran into this problem when I did mine, both sets came off P1K5D’s but one was older than the other and had a different front shock.
65DAD976 1493 4B0B 90C3 287A1051C33B
5BD1C168 1C98 42DE AEA7 D8580F9F2C6B
Reactions: BWAF and Mudwing
Gunslingertom
Gunslingertom
104
171
SW Missouri Ozarks
View attachment 177440 View attachment 177441
So, if those are the shocks that you had, would you put the heavier spring shock on back or front? Since the 700 is basically mid engine, it seems fairly well balanced front to back.
Reactions: Russ989
Russ989
Russ989
22,573
146,573
Put the heavier spring in the back for when you’re using the hitch.
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
in the back.
Also the front shocks are different on the 3 seater and 4 seater cause the back passengers dont sit directly over the rear tires. So the front needs a little more on it. If i was doing the swap . Id run the shocks for the equivalent machine. Might show better results.
1k3-700-2
1k5-700-4
Russ989
Russ989
22,573
146,573
in the back.
1k3-700-2
1k5-700-4
The ride on my 700 was day and night after putting the 1000 shocks on. I recommend this upgrade to anyone with a 700-4.
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
Yeah i plan on it later maybe just have to get some limiter straps and see what all i need to swap to get to the same height i am now.
Reactions: Russ989
Gunslingertom
Gunslingertom
104
171
SW Missouri Ozarks
Actually this is a pic of the actual shocks that I purchased. They look nearly identical to me. No extra coils, same length. IDK, it's weird.
On another note, are limit straps going to necessary with the 100 shocks on a 700? Because if they are, it's the first I've heard of it.
Pioneer Shocks
BBLASER
159
277
Phoenix
Just in Case anyone needs a complete set of 1000-5 factory shocks, message me. I have a set I took off after 200 miles.
Reactions: Alan_Vander
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
The first ones posted was a dual rate versus a single rate spring. These are just single rate springs with different spring rates.
For my setup id need limiter straps im running a stacked lift at 5 inches. For just the 1k shocks you shouldnt need limiter straps.
56,770
The pictures @Russ989 shared were stock fronts from @Smitty335 2016 1k5 and my 2018 1k5 that we sent him to do the swap. Somewhere along the way Honda changed the springs.
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
Probably 2017 isnt that when they changed to a dual rate on the 700?
G
GWH
748
2,475
Las Vegas Nevads
Anybody in southern Nevada that wants a set of ft shocks off a 2016 deluxe 5 1000 let me know .you can have them,they look like new
nitzo
nitzo
521
1,105
East Coast, Florida
The one on the right is a progressive spring, no? On the top photos.
Reactions: JTW
