P700 Pioneer 700 with Can-Am Commander Shocks
Offroad407
Offroad407
5
Florida
Does anyone have any spare or extra 14mm sleeves or tubing for the rear shocks. WTB and will pay for shipping.
Offroad407
Offroad407
5
Florida
I was hoping to get the 14mm for a proper fit, but how did you get the sleeve in the bushing. Did you drill it out?
Offroad407
Offroad407
5
Florida
Alright well if I can't find any spare 14mm I'll Pm you from the 15mm sleeves.
Cazadore
26
19
Az
Spent the day installing Commander springs and shocks on the front of my 700-4. Went through two spring compressors before finally just using the four ratchet strap method. What a pain. I'm not sure what I did wrong but I ended up with about 4" of lift on the front. Since I don't have the rears yet, I put spring spacers on the rear to lift it about 2.25". Took it out for a ride and now am thinking what the heck did I do wrong. My fairly smooth ride has turned in to a clunky, junky, rough, Clampett mobile. Steering feels loose as all get out, bumps transfer straight to the steering wheel. Any ideas?
7,143
27,162
Pictures of the shocks before and after install please.
Cazadore
26
19
Az
I'll have to get pics tomorrow. I'm wondering if I have the preload adjusted way too high.
SundayRdr
SundayRdr
575
1,179
McMinville Tn
The fronts bolted right up. No spring compressor or ratchet straps needed. The only major noticeable thing after the install was a great ride.
Cazadore
26
19
Az
I had to assemble the springs/shocks prior to install. I bought the springs locally off of a '12 Commander and the shocks off of a guy on a Commander forum, also a '12 Commander. After assembly, they bolted right up, no problem.
Cazadore
26
19
Az
Ok, I will have to get them tomorrow during the daylight hours.
Cazadore
26
19
Az
57820126 91E0 4549 9B80 7F9FC42D49A2
7,143
27,162
I used lowest preload setting.
20160519 194102
Here are mine before install.
Yours spring's look a little different!
Reactions: eastenn
Cazadore
26
19
Az
4CA3D029 A225 4829 907C CBA41E6EC6B8
Is it possible that I put the rear springs up front?
Cazadore
26
19
Az
I can’t see the numbers on the installed ones. I’ll pull them tonight and check. The back Springs, I think, are 706201124.
Okay, problem solved, the part number shows "yellow front spring". I knew something was wrong. Well at least I know how to break down the springs now.
PARTS SEARCH RESULTS
ASSEMBLIES WHERE 706201124 IS USED
Reactions: Tramguage1
7,143
27,162
I was VERY pleased with the Commander swap on my 700-4.
