P1000m5 Project no more butt gravy
BWAF
BWAF
I get paid to pass gas
8,857
42,437
Carthage MO
Beer check
61432d1eab51013be8c0d014f1c3687e
Little machine work
11178d090ca36b778d1b4640f355f3c7
Mount Dtdp Switch down for heat in cab up for NO more gravy
E8b4f2c770f4ff8ad70ddc2a2573941f
Mount fan and brackets
393db8e6c7c5d9a2612f5d312cb31c0e
Trip to Colaw Rv for vent
416be4580abb27a39c5162a53c7d4da3
4 pin trailer plug ext.cut in half so front plastic can come and don't half to unwire
B94085f57878afca78e90e5e98ea8c18
Need to cut 4" hole and put flex pipe on.Repeat step one as many times as needed
Bde0fa090666b82f327ca07424a69fa8
BigOL3
BigOL3
2,994
8,919
Beer checkView attachment 71899Little machine work View attachment 71900Mount Dtdp Switch down for heat in cab up for NO more gravy View attachment 71901Mount fan and brackets View attachment 71902[/ATTACH]Trip to Colaw Rv for vent View attachment 719144 pin trailer plug ext.cut in half so front plastic can come and don't half to unwire View attachment 71905 Need to cut 4" hole and put flex pipe on.Repeat step one as many times as needed View attachment 71903 View attachment 71904 View attachment 71906 View attachment 71909
Good job.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
That's basically what I did. I definitely need a second fan.
I think @CumminsPusher had mounted an 8" radiator style fan at an angle under the passenger seat blowing to the back. I think I'm going to do that before summer.
Nice thing about your set up is you can reverse the wires and blow warm air in when it's cold. That's what I do
BWAF
BWAF
8,857
42,437
Carthage MO
Polarity reversing switch it's already there
MountainMan
MountainMan
54
Spokane Valley, Washington
Beer check
Little machine work
I like this. It is on my list to do. I am more interested in using it as a heater during cold weather. I am curious, how noisy is the fan? Can you hear it while the engine is running? Also, how well does it work when running the fan in reverse? I am curious how efficient the blades are when running them backwards.
BWAF
BWAF
8,857
42,437
Carthage MO
Not quite done yet ,with cab comfort kit don't think it will be to bad
Reactions: Lady01 and pct
105,693
One things for sure, that there Banquet is good stuff!
Reactions: Lady01 and BWAF
BWAF
BWAF
8,857
42,437
Carthage MO
Well under seat is done left flex pipe off for now still get air flow both ways . Sound level not to bad . Now just finish up some wiring may add second battery while here .F4d24b871e5edc0eb4f4615ce238127b94e7e9e1247fdb265fa6376326e8ddf4
105,693
MountainMan
MountainMan
54
Well under seat is done left flex pipe off for now still get air flow both ways . Sound level not to bad . Now just finish up some wiring may add second battery while here .View attachment 72002View attachment 72003
I sure like the looks of that. Can you rotate the louvers to direct the air flow or close them?
BWAF
BWAF
8,857
42,437
Carthage MO
Rotate and close but took out the closing part thought it might vibrate shut
Reactions: Lady01
BWAF
BWAF
8,857
42,437
Carthage MO
Added flex pipe from vent to fan back in the winter moves way more air with it on I think both ways but believe it mad it a little louder
BWAF
BWAF
8,857
42,437
Carthage MO
@Eltobgi you found one of my old threads I've been searching for some of these even with title i still cant find when i search in tapatalk or on website ! It's like after I bought lifetime membership all my old stuff disappeared cause I was on here free for about a year .@Hondasxs
Reactions: Lady01 and Mudwing
