R-Max
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,543
Central Iowa
Apparently tender springs are supposed to be like by design when sitting. They are there to help when fully extended. I find it hard to believe every tender spring on a stock vehicle is like that because nobody paid attention.
Explain a scenario where that logic works. When are the shocks at full extension in a way that the extremely light tender springs provide a benefit upon compression.
Reactions: Biteme
1HasBeen
1HasBeen
299
755
Wickenburg, AZ
Tender spring is only there to keep the main spring from getting loose and rattling around at full extension.
Reactions: Biteme and CID
My brother has been looking into sxs and has liked my Pioneer. He needs the back seats for the kids. I told him to steer away from the Pioneer just because of the heat issue. It was bad enough in my 3 seat even with fans. I told him If I had kids I'd be taking a serious look at the rmax 4.
Gotta say I understand the heat issue some but it does seem like people are getting soft nowadays. We’ve usually had people in back, most of the time kids as well and we just always rode. Ya on hot days it’s warm but pull out windshield it’s not bad. Better then sitting home playing video games. Had very few b****, just explain the heat, dust or elements are part of it and go. Never heard anyone in or around our group say the back is too hot or uncomfortable to go for a ride. Hell I sit back there a lot and just enjoy being driven around.
We did the automotive fan years back and it drastically helps but now coming on 3 years with the newest machine and still haven’t bothered installing again. And we don’t kitty it we will go out any available weekend come sun or snow.
On my review of the RMax I mentioned theres no interior heat for a positive in the summer but that’s also under negative for winter and night rides. Just like the X4 and RMax we drove our Wolverine R-spec has no interior heat and it’s been more negative then good being completely honest. We sometimes take out the armrest storage to get a little heat but it’s miserable when cold where the Pioneer is nice. Especially after we learned to take out the 4”x4” access panel for additional. It’s true 4-seasons around here, we go from well over 100 to below 0 sometimes. Haven’t needed an additional heater in Pioneer and have learned how to get rid of heat. I swear some people should just buy a Jeep for comfort.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,543
Central Iowa
Yea you're right Dave. When he rides in the summer and his 2 year old is burning up in the back seat he should just tell him to stop being a kitty. Got heat stoke kid? Stop being a kitty. Is that exhaust header under your feet burning you? Stop being a kitty. God forbid a $20k unit not get so hot it melts plastic or even be tolerable to ride.
You're the most hard core of the hard core guys. We should all just sell our machines and get a Chrysler town and country mini van instead.
When you have the option to buy a machine that doesn't cook you out in the summer vs one that does. That doesn't make you soft, it makes you smart.
Well what I did say that you may have missed was the fan does help a lot. Again with flowing air it’s not a problem imho anyways.
I think the programmer might help as well but we’ve been doing ok. And no I don’t know anything about kids riding in the machine, lol.
That’s my grandson riding up front with daughter and husband while I rode in those horrible rear seats with my wife having fun on a warm day, even with full glass
3A8DF807 0007 4B7C A2E4 D6478F29E89C
And on a hot day just a few kids
I know nothing about it lol. Bought a short 5 seat for a reason and we use it. Just saying CD4958FF 1D62 4FD7 A3DA 563166A7B6A2
Ragnar406
Ragnar406
The Great Bald One
4,460
17,085
Bella Vista, AR
Yes, After doing some reading the R-max has a Duel spring shock and the tender is supposed to be near compressed but not coil bound.
The other system is a True Duel rate spring shock with crossovers. in this type of shock the top spring is not supposed to be compressed.
I think most people simply call the top spring a Tender spring However i think that name only applies to the top spring of a Duel spring shock
Really cool to read how they both work The Truth about Dual Rate Springs
Ragnar406
Ragnar406
The Great Bald One
4,460
17,085
Bella Vista, AR
2012 polaris rzr xp 900 front shock
picture 1
There are many “marketing” rumors about Dual Rate Spring (DRS) systems for the UTV market. Some true and some not. For this reason we feel it is important to understand how the system works and why. In a standard, single spring application (picture 1) there is one spring per shock. That spring has a single spring rate which is determined by the spring manufacturer when it was made. Different wire diameter as well as the number of coils per inch can affect the stiffness or spring rate. The spring rate is the force in pounds per EACH inch of compression the spring will exert. For instance, on a RZR 900 the front coil spring is approximately a 250 lb spring rate. This means that for each inch you compress the spring either by sitting in the car or landing from a jump the spring will give you 250 lbs of force for EACH inch it is compressed. Another way to look at it is if the spring is compressed 1 inch you will measure 250 lbs of force. If it is compressed 4 inches you will see 1000 lbs of force and if it is fully compressed, say 8 inches, you will see 2000 lbs of force. In this single spring and thus a single rate system, things are pretty simple and linear. If you lower the spring rate to a 200 lb spring you will feel a smoother ride with less chop and vibration because you are feeling 50 less pounds of force per inch on the frame and your butt as you drive over a rock or hole. The negative to a lighter spring is that when fully compressed ( 8 inches with a 200lb spring ) you only get 1600 lbs of force, per corner to help stop you from bottoming out. That is 1200 lbs less if you add up all four corners!
Img 1915
Pic 2, dual spring system, NO cross over ring
In a Dual Spring (not dual rate) system ( picture 2 ) you have two springs on your shock that are separated by a plastic or nylon spring divider. The divider is designed to keep the springs in line as well as act as a bushing for the shock and keep the springs from rubbing on the shock body. The Dual Spring system is linear just like the single spring system is with one exception, it uses a COMBINED spring rate. If the shock were compressed one inch then BOTH of the springs would compress a little to add up to that inch. Also, since each springs rate is not added together the combined spring rate can be considerably lower than a single spring system. Lets take the 250 lb spring from earlier and use TWO 250 lb springs in this case. The formula for a dual spring system is as follows: top spring (TS) times bottom spring (BS) divided by the TS plus the BS. ( TS x BS ) divided by ( TS + BS ) Her is how that goes: ( 250 x 250 ) divided by ( 250 + 250 ) next (62,500) divided by (500) equals 125 lb combined spring rate. In this dual spring system you have a combined rate of 125 lbs per inch of compression. What? I know it doesn’t make sense that two 250 springs give you 125 lb spring rate but think of it like this, each spring compresses half of an inch (adding up to ONE inch total movement on the shock) which is 125 lbs of force PER SPRING. This force is TOTAL force. You do not add each spring’s force together to get the total, only the force it takes to compress the spring half of an inch. Still tough? That’s ok, just accept it. It is true. Below is a picture of a Dual Rate spring chart for you to use as a reference any time.
Dual rate chart large
Now lets compress this Dual Spring system 8 inches. The total pressure exerted is 1000 lbs per shock. Remember you now have a combined spring rate of 125lbs per inch. You would most certainly bottom this system out in a medium hit. In order to get back to the same spring rate as a stock, single spring system you would have to use two 500 lb springs. (500 x 500) divided by (500 + 500) = 250 lb combined spring rate which is 2000 lbs when compressed 8 inches. Why bother running a Dual Spring system if it is the same linear rate as a single spring? Good question.
Img 1877
picture 3
Here is where it gets good. In a true Dual Rate Spring system there are two springs and a spring divider just as before but you have one crucial extra item, a cross over ring. ( picture 3 ) Also known as a cross over nut, rate nut or secondary rate nut. This ring threads onto the shock body inside of the upper coil spring. It’s job is to contact the nylon spring divider where you set it. Once it contacts the spring divider, when the suspension is compressed, the upper coil spring is no longer used. The cross over ring has stopped the upper spring from compressing. Why is this good? Because, now you are only using the lower spring in your Dual Rate Spring system. Go back to our 250/250 example. Until the cross over ring hits the divider you are feeling a 125 lb combined spring rate which is plush but not enough spring to stop you from bottoming out. Once the upper spring is cancelled out by the cross over you are now feeling the Single lower spring rate of 250 lbs per inch! You just doubled your effective spring rate by going to a Single spring. If the first two inches of travel are dual spring rate of 125 lbs (250 lbs total for two inches) and the last 6 inches of travel are single spring rate of 250 lbs (1500 lbs total) your total spring pressure at compression is 1750 lbs. The cool thing about this set up is that your butt got to feel the soft, plush ride of a 125 lb rate for the first two inches of travel before you hit something big enough to compress past that and get into the 250 lb lower spring for the rest of the travel.
But wait, we are still missing 250 lbs of total pressure when fully compressed compared to the stock single spring. ( 1750 lbs versus 2000 lbs ). No problem. Lets run a 200 lb upper spring and a 300 lb lower spring. To figure the combined spring rate just (200 x 300) divided by (200 + 300) next (60,000) divided by (500) equals 120 lb combined spring rate. Now in this Dual Spring Rate system the first 2 inches of travel you are feeling 120 lb spring rate in your butt. Nice and plush. The last 6 inches of travel you feel a 300 lb single rate. Let’s add up the total pressure when compressed. 240 lbs for the first two inches, 1800 for the last 6 inches is a total of 2,040 lbs. There we go! Back to almost the same compressed force as the single, stock spring gave us but instead we get to enjoy the softer, smoother ride for the first 2 inches of tire movement at a 120 lb rate! This is the benefit of a Dual Rate Spring system.
THERE ARE ONLY TWO WAYS TO GET A TRUE DUAL RATE SPRING KIT, USE A CROSS OVER RING OR BIND THE UPPER SPRING!
If the upper spring is designed to go to bind (fully compress) during compression then when it binds you have taken it out of the system completely. This does the same thing as a cross over ring. When the upper spring is removed from the system you are now using the lower, heavier spring only. There are many negatives to this. First, you can not control when the spring goes to bind. If you add more weight to the car it will happen sooner. If you raise the ride height up it will happen later. There is no functional adjust ability to when the system gets stiffer. Second, when the spring binds it will show this by rubbing the powder coat off of the spring where it contacted each coil. This is the tell tail sign of a coil bound situation.
Coil bind 1
The factory RZR 1000 front and rear upper springs do this. The front happens way too late in the compression stroke and this is why the front is so soft and has a lot of nose dive under braking. The rear is at coil bind right at ride height. This means the rear is on the stiffer lower spring right away and why the rear has a tendency to buck and kit in the whoops and jumps since it is stiff too soon. Binding the upper spring is a cheaper way to create a dual rate spring system since you don’t have the cost of cross over rings but it needs to be designed perfectly. If not, it won’t work right. Also, if you do anything to the car (bolt on accessories, drive harder, add people) you will change when the spring binds and you can’t adjust or fix it. The second negative is that a coil bound spring tends to fail faster than a non bound spring. Case and point, factory upper front springs on the RZR 1000. Breakage of this spring is very common and the binding of this spring late in the travel is a big contributor to the issue. There are people who market their dual spring kits as dual rate because the upper spring goes to bind. Cool, just look at the upper spring powder coat and see if it really does.
There are Dual Rate spring kits on the market today that have never been sold with a cross over nut. They are not Dual Rate, only Dual Spring kits. We have seen them here and rated every spring on the car. On a RZR 900 they will often use a 250 lb lower spring with a short 1000 lb upper spring! Wow you say? Let’s do the math. (1000 x 250) divided by (1000 + 250) equals 200 lb LINEAR COMBINED SPRING RATE. This is lighter than the stock spring rate and would be more plush than stock but less total resistance when compressed. Remember without a cross over ring or coil bound upper spring this is still a single spring rate system. Even if this system had a cross over ring or a bound upper spring it would only change from a 200lb rate to a 250lb rate when the cross over was engaged. This is such a small spring rate jump for a secondary rate that it is all most not worth doing. Typical dual rate jumps are in the 100-300lb increase range. Another thing worth mentioning is that it is mathematically impossible to coil bind a 4″ tall, 1000lb spring with a 250lb lower spring on a RZR 900. Here is why. In order to bind this upper spring it would have to be compressed a little past 2 inches. This would require over 2000lbs of force to accomplish. Since the lower spring is 250lb rate this means it would have to be compressed over 8″ to get over 2000lbs of force. With a total shock travel of 8″ you could never get the required spring force to bind the upper spring. Remember that the upper spring will compress over an inch at some point which means the lower spring could never compress past 7″ in this spring set up. Even if it could bind it would happen way too late and have too small of a spring rate jump to be of any use. Remember, you can always check the powder coat on the upper spring and see if it actually binds.
Finally, we did not invent the Dual Rate Spring system that uses a cross over ring. It has been around for decades. Every competitive Trophy Truck, class one car and long travel sand car uses this system. Why do we market TRUE DUAL RATE spring kits with a cross over ring? Not to sell our cross over rings, that is for sure. You can buy your own cross over rings for any shock and use them too. You just have to pay a shock guy to put them on since they are not two piece. We market TRUE DUAL RATE spring kits because they are the best system you can run. From a spring stand point, it gives you the softest, most compliant and versatile ride quality possible over any and all terrain. We know from experience that this spring system combined with proper shock valving is the best possible system to run. Why doesn’t the factory run it on all their cars standard? Cost. Two springs with a divider and cross over are way more expensive than a single spring. Some accountant has done the math and figured they won’t sell enough units to justify the cost because most people just don’t know how great a good ride can become. You don’t have to take our word for it, just Google up a picture of every winner of every SCORE, BITD or LUCAS OIL race in the last 20 years and you will see a dual rate spring system with a cross over ring on it. Educate yourself and see how smooth things can be on your UTV!
Tigermark
Tigermark
Outside looking in.
Well,
He is the PNW Legend!
Well,
Really?? That’s not what I was saying at all. Wasn’t trying to be a tough guy talking my experience riding alone, was talking experience riding with family, friends and whoever else tagged along.
All of our local Pioneer friends ride with their family as you know and met. I think a couple have factory heat shield but that’s it. They all ride regardless of temps. I just honestly haven’t heard many complaints, no one wants a fan even.
I understand that some try to run full cab and obviously you can’t do that on any machine except A/C Polaris but I wonder if some machines run more rich or something. I’ve seen a few rigs melt the back but none of mine did nor my local friends. It gets hot here and we all still go, avoid puddles like the plague I’ll admit (if ya know what I mean lol)
Suuuure..... maybe y’all should just hook chains and get it over with!?
Russ989
Russ989
22,645
147,291
My 1000-5 is pretty good, it’s not the HOT BOX everyone keeps talking about. There is heat but it’s not that bad.
Hook drive belts instead, the epic failure rate will be a YouTube sensation. Save the chains for gearbox machines. 😂
Ya not sure a belt wants to pull a fully loaded 6k Jeep through the muddy trails 3 miles back to camp. His Polaris friends sure flagged the Honda down quickly lol.
