P1000 School me on toy haulers
wyo700
wyo700
413
210
Bought our toy hauler back in 2012 when they were more built for atvs. Had to take it down to dealership to make sure my 700-4 would fit inside before we bought it. It's very tight but it fits. Honestly the only thing that stopped me from getting a 1000-5.
Reactions: JTW
HivoltageHonda
HivoltageHonda
374
367
Hernando, MS
Anybody know about the puma unleashed 5th wheel toyhaulers? Looks like you can get some for around 30k which is about the most I wanna spend since it's my first one.
T
tomthegunwilson
5
14
Arizona
Pop-up toy hauler is the way to go!
20200707 185612
Ridinfool
Ridinfool
36,144
386,049
Western North Carolina
D84C8219 999A 4065 89D0 F235744B8B8F
This is my rig, fuel 287 TT it’s 38 ft long it weighs around 12500 fully loaded, has a tongue weight of 1400-1500 pounds I pull it with a19 F-350 dually 6.7 diesel my P1K-5 fits no problem top to bottom but side to side it’s a tight fit. If you are wanting a separate garage will most likely end up with a 5er. Some things to consider when buying a TH...
Will your buggy fit. Size of holding tanks, most manufacturers give you a big fresh water tank and smaller grey and black water tanks, grey and black tanks sizes are important if your dry camping... no hookups. Best thing you can do is measure your buggy height and width then go on line and search for what you think will work for you and then go and walk through them, pics are great but live and in person is best. I looked at dozens of floor plans and pics on line and would go and look at them in person and would change my mind, finally settled on the fuel 287. Like was said earlier, what’s your budget? Can you pull it with your current rig or do you need to upgrade that? Hope this helps some good luck with your choice and don’t forget to post pics.😎
MAJspoon
MAJspoon
19
96
Cadiz, Ky
I have owned tandem toy hauler, enclosed trailer, and 40 ft voltage 5er. Personally I would like to go back to camping in a 16-18 foot cargo trailer. They are much cheaper, less to go wrong and still offers a dry warm or cold place to put your head. Modern toy haulers/rvs are very fragile. Just look at the interiors. They look nice but you are hauling a lot of crap around you really don’t need unless you are going to live in it. if you must buy a toy hauler and cost is not an issue look a ATC and Sundowner. Both companies build custom aluminum toy haulers that are just built better. But I would also tell you to consider a small motorhome in a ford or Mercedes diesel chassis and pull your p1000 on a trailer. consider that you will spend at least $50000 on a decent truck and the motorhome starts looking more feasible.
Reactions: lee
