A
I have a 2020 Pioneer 1000 EPS and was performing an oil change of the sub transmission and over torqued the oil drain plug cracking the casing around it. Now its a much bigger problem and I am pretty frustrated. I have a paper copy of the service manual but looking for some advice.
Assume I have to remove the sub transmission completely to fix?
Do I need to drain the new engine oil I just put in, in addition, to the sub transmission oil?
Assume I will need these replacement parts to complete job? Anything else?
GASKET, SUB-TRANSMISSION CASE
21206-HL4-003
GASKET, SUB-TRANSMISSION COVER
21205-HL4-003
CASE, SUB-TRANSMISSION
21100-HL4-000
COLLAR PARKING (its cheap and there is a recall so figured i would get one)
24563-HL4-000
Thanks
21206-HL4-003
21205-HL4-003
21100-HL4-000
24563-HL4-000
Thanks
