So don't use this panel it is a 1/4" too tall to fit in the good spot. The panel I used it slightly different than Delton's. The one I used has the resettable breakers which makes the panel taller, Had to do som butchering to get it to fit. Anyone else would probably be fine but my OCD is redlineing!
Keep it up! This is awesome! Great pics! Oh, where are the rock light and interior lighting lol
In the mail bro
Dont know why it was taller cause mine also has resettable breakers. They glow green when good and red when they trip. Must be fairly tough as it's over a year old and sees pressure washer often (well maybe not OFTEN but when/if I clean it lol).So don't use this panel it is a 1/4" too tall to fit in the good spot. The panel I used it slightly different than Delton's. The one I used has the resettable breakers which makes the panel taller, Had to do som butchering to get it to fit. Anyone else would probably be fine but my OCD is redlineing!
I'm with @Delton. I don't know why that one is off the bottom.View attachment 45079Panel is in, had to cut a grove at the top of the spot to slide the panel in so the bottom screws would grab some plastic. Stupid and impatient, I shoulda just bought a shorter panel. It works though, the pic makes it look like it hangs really low but it only hangs about a 1/8" low. I can see my OCD a$$ buying a sheet of 1/8" ABS and a blank carbon fiber 6 gang panel without the overload breaker openings and redoing the whole panel to repair this atrocity!
