P1000m5 True Battery Isolator Install Question
Reno58
Reno58
74
Middle TN
Okay, my first dumb question.......Installed second battery (Odyssey PC925) along with battery isolator (True UTV-SBI-15CM). Double checked install and cranked up P1000, blue led light popped on, no problem. Shut engine off, but little blue light has been on for about 4 hours!?
I've seen other posts on this, sorry for beating a dead horse here, but is the light staying on because my auxiliary battery is new and slightly below a "full charge" or is something amiss?
Again, my apologies to the dead horse.
Thanks for your comments.
Reactions: knuckledeep
knuckledeep
knuckledeep
my trailer queen is trashy
1,052
3,470
Eustis florida
It could be what are the voltages on the meter
knuckledeep
knuckledeep
1,052
3,470
Eustis florida
The voltmeters hooked to a key hot ??? mine stays on for a bout 5 to 10 min after i shut it off
Reno58
Reno58
74
Middle TN
Looked up True's web site, it stated they usually have knowledgeable personnel that will answer phone 24/7/365, so I called their number. The company owner picked up, answered my question (it is working properly) and was very nice. I highly recommend this company!
knuckledeep, thanks for your input.
You’re not the first to have this question or experience the same level of customer service! Great product and company!!!
7,197
27,839
To test operation turn off machine, then turn on devices connected to Aux battery. When the voltage in the Aux battery drops below the preset voltage the isolator will open the connection to the main battery. (The blue light will go out)
I have talked to him also a couple times. He is a great guy!
my99svt
my99svt
I identify as a lesbian
1,267
5,248
Broken Arrow, Oklahoma
My blue light quit working after about a month. But watching my volt meters i can tell the switch still functions properly.
Reactions: Dp5hunter
Reno58
Reno58
74
Middle TN
Exactly what I did to get the light to go off - turned on ignition (didn't start the engine) and turned on headlights. In about 20 sec the light went out.
All is well.
casey2131
casey2131
10
10
Florida
Hi, I was under the impression that you hooked all of your main wires with higher voltage from your amps, LED lights, and speakers to your main battery directly I hooked my gauges up to a positive power bar, when the voltage goes down on that to where it would be close to unable to start, it would kick over to the spare, am I missing something? Thank you.
64,640
Hi, I was under the impression that you hooked all of your main wires with higher voltage from your amps, LED lights, and speakers to your main battery directly I don't mind gauges up to a positive power bar, when the voltage goes down on that to where it would be unable to start, it would kick over to the spare am I missing something? Thank you.
no, no, no.. you have it backwards.
All accessories should be hooked the secondary battery.
The Tru isolator bridges both batteries as long as the main battery has more then 13v's. Once it falls below the threshold it disconnects. Saving the main battery from drain.
Edit....
The blue light acts as a voltage indicator. If it is on. That means your main battery has more then the threshold. (13v +-). If it is off. That means the main battery has less then the threshold.
casey2131
casey2131
10
10
Florida
Edit....
Hi, thank you for your reply. That's weird because that's the way I had it hooked up from the beginning and every time I looked at my voltage meter it said it was @12 or under sometime 11. Something wasn't right, when I moved everything to my other battery the main battery everything seemed to be working as it should. Always showing 13.9 volts when it has a draw and 14.1 without a draw. Should i put them back ? Thanks so much for your time.
64,640
IDK, I'm not going to claim to be an expert at this. And it gets confusing too.
But the ultimate goal is to not drain the main battery even if you left the accessories on all night and day. The isolator interrupts this connection once the voltage drops from the source battery. Thus allowing you to drain the extra battery but not the start battery.
I would most definitely take another look into your setup.
Reactions: JTW
casey2131
casey2131
10
10
Florida
UPDATE: I put everything back on secondary battery and hooked up separate voltage meters for both batteries I think I was reading the secondary battery voltage after it was going down. Thanks again, fingers crossed. Also hooked up a trickle charger for secondary battery for good measures. LOL Thanks everyone !!
Reactions: JTW
64,640
LOL... Great,
Side note.
There have some reports of the voltage meter being on an incorrect circuit and causing misreadings. Sorry, that's over my head to figure that out. lol.
Reactions: JTW
