P1000 Wheel bearing greaser
208,011
Yeah, but you drive a rzr. Lol
Where is the nasty stuff coming out?
They've been doing this for years on boat trailers, only it's built into the hub. Now there's an idea, grease sert behind the center cap on the wheel.
Reactions: JTW and sharp
208,011
^he's got a point. I couldnt use it. i have a hard time not crushing my center caps as it is.
Don't have in gouges on my center cap yet, but my wheels are a different story.
Reactions: sharp
208,011
A racing buddy of mine, him not me, showed me a neat trick with sealed bearings. Very carefully pry the seal out of a sealed bearing add grease to a brand new bearing, reinstall seals, now you have a sealed bearing full of grease instead of little.
Reactions: popeye and sharp
208,011
Drill and tap hub spindle for sert, make grease passage to area on both sides of bearing perpendicular to hub shafts don't use sealed bearings, that's how boat trailers hubs are made.
Isn't that basically what a buddy bearing is?
IMG 4512
208,011
No The spindle has no grease passage to put new grease right on bearing
Reactions: JTW
YEA i was reminded of that on the rescue missions i tagged along in and parking lot repairs i helped with during the take over. but im sure that kinda stuff never happens it was all just a fluke :)
Lol.. should'a bought a Kubota!
Reactions: Shannon840
P
patpete
65
149
Alaska
I got one from “machined integrations “ works great. Remember to turn as you pump grease in. I was really surprised when my brand new wheel bearing took 40 pumps of grease before any came out
Reactions: TripleB
popeye
popeye
3,273
14,641
kapowsin, Wa
Been doing that on my dirt bikes and quads since I was knee high to a grass hopper. Have found over the years a razor blade to the outside edge of the seal to pry out removes it, and won’t disturb the inner seal portion
Reactions: Plumber32 and JTW
Ummmm, me thinks you may have put too much in there. I would expect you’ll have a mess on your hands before long.
popeye
popeye
3,273
14,641
kapowsin, Wa
Watch this video, granted it’s of a canam bearing, but I’m sure Honda’s come with minimal grease also
Reactions: TripleB
Mobius396
35
56
Muskego, WI
How often are you guys greasing your bearings if your not mudding? Is this something that should be done fairly soon after purchase?
