P500 Wont shift or start
Talen
Talen
159
188
Central PA
Was in a creek at end of ride, when the check engine light came on. And the shift indicator turned to the minus symbol. I couldn't shift. Limped back to car in first. At home it started back up. Manually put in reverse. Washed it. Now it won't start either. Idk
Mudder
Mudder
NTC Ambassador of Walls
11,660
88,041
Completely dead electrically or any display now? Tried neutral or emergency shift tool and rocking (ensure in neutral or a gear with brake interlock if no starter action.? Fuse checks OK? If it turns over, could be water in gas via vent. Just throwing out some guesses, good luck. P500 - Display and Shift Dead
Talen
Talen
159
188
Central PA
The dash did work when this happened but displayed the minus symbol instead of gear. Check engine light was on. And it would turn over.
But it did start now a day later. And shifted. Some thing must have got wet. I need to determine what, so I can put some dielectric grease on it
Pawnman87
Pawnman87
27
59
Murfreesboro, Ar
Alright fellas finally got the call from the dealership and they found the problem and got her all patched up. The tech guys found a new issue with the p500 they said they hadn't seen before my rig has more miles than they said they ever had one come in with and that could have attributed to the issue. on the back side of the motor just above the rear drive shaft and gear position sensor there are wires from one of the sensors that comes across the back side of the engine had rubbed and vibrated against the motor and were grounding/shorting. They said that lots and lots of riding would probably and eventually cause the same problem on all p500's. It was an easy fix they said but devastatingly difficult to find. On the plus side I talked my dealer into throwing in the extended warranty when purchased as part of the deal and it actually paid off this time and they covered it no charge! I will post pics of the wires in question as soon as I figure out how on this phone lol!
Pawnman87
Pawnman87
27
59
Murfreesboro, Ar
the red is where it had been rubbing the engine the green is where they repaired and re-ran the wiring
20171003 154513
William
William
1,442
2,887
Flowood MS
Mine Is rubbing the same spot! Will be wrapping it this weekend!
William
William
1,442
2,887
Flowood MS
And thanks! Great post...
Mudder
Mudder
11,660
88,041
@Pawnman87 , thanks for taking the time to provide great marked up pictures. Good post to help many others!
Reactions: Miss_Oak
66,871
Let me know if y'all is bad too. I will break it into a new thread for better visibility.
William
William
1,442
2,887
Flowood MS
Mine is not bad, but I can see where those with more mileage would have problems. It's definitely a need to fix thing though!
O
oldfortyfive
604
1,360
Illinois
I just went ahead and snaked some of that corrugated wire covering over the harness as added protection.
Reactions: Rustell
Mudder
Mudder
11,660
88,041
Rubbing on my 2017 too. Very hard to get to but may take the left rear tire off to get arm in there. At least three rub spots and cables are only in a thin plastic sleeve. Little or no slack to work with. PITA. Agree with @Hondasxs to make a post for visibility to others. Going to buy some 1/2 inch cable wrap.
Reactions: Miss_Oak
William
William
1,442
2,887
Flowood MS
Fixed mine today... super easy...
56A5D606 BF59 4B61 B59E FFF06C8D14FF AA67C81A 615C 4D9D 93F5 A0BE1B7C2831
Reactions: Rustell
Rustell
Mine looked ok, but it's sure worth it if this keeps you from getting stranded somewhere. I'll do it just for something to do..
William
William
1,442
2,887
Flowood MS
38A57CAC 546B 4D8A 8BEA DF0C846865B1
Also check the wires running up the side of the rectifier/regulator. Mine was rubbing bad there! C91414B2 056F 471C 91A6 C5E36DC82ECF
