P1000 Big horn 2.0
jwfirebird
jwfirebird
927
1,446
western ny
don't know personally, I don't ride gravel or roads, some of the reviews on rocky mountain and those say they are fine I can imagine it would be, is a fairly heavy tire. obviously not going to be like a bighorn or dot radial tire but those get stuck all the time around here and they are worth it
Thank you!
Cecilthelion
Cecilthelion
94
165
Brooklet GA.
Here are some pics of the cracks. This is driver rear. I replaced passenger rear about a month ago for same condition. Now the 3 originals have cracks.
20190218 172825 20190218 172937 20190218 173009 20190218 172703 20190218 173037
Reactions: CumminsPusher
jwfirebird
jwfirebird
927
1,446
western ny
i would guess it would be combination of those being a really hard tire and those are the brittle areas and too much air. would try 8 to ten psi at most. i mostly look at the bulge when i get new tires, got to have some bulge on the sides to ride decent as well as puncture resistance. can also monitor the tread if you get it dirty all the tread blocks should be well covered if the outer one dont its too much air. most radials are 3-5 less than the oem bias rating is what i end up at
Cecilthelion
Cecilthelion
94
165
Brooklet GA.
I kept them between 12 and 14 psi. That’s what the manual says and I noticed that with lower psi it would feel loose at higher speeds.
Reactions: Mopower58
jwfirebird
jwfirebird
927
1,446
western ny
being a hard radial its not going to be anything like what the manual says, original bias balloons need a ton of air to be stiff. anytime you have after market tires you have to play with the pressures to make a call
Reactions: Cecilthelion
Cecilthelion
Cecilthelion
94
165
Brooklet GA.
That’s the thing. The Big horns come standard on the LE model.
jwfirebird
jwfirebird
927
1,446
western ny
hard to believe they would recommend the same for bias on mine and big horns, but regardless, I always disregard what they say any way. you have to have some bulge or you will have problems with traction, flats and cracks
Cecilthelion
Cecilthelion
94
165
Brooklet GA.
Update time. Maxxis OE warranty dept has been in touch. The quality engineers want to physically look at the tires. Have to ship them off to them so my ride will be on blocks for awhile.
Oh boy, I hope they’re paying the freight!! ;)
dnjones161
dnjones161
583
1,712
That's crazy they would expect you to put your ride on blocks, esp this time of year! Step up and replace them and ask for the old ones back if you need to geeze
Cecilthelion
Cecilthelion
94
165
Brooklet GA.
I know right. Here are some e pics. It's kind of funny.
20190316 155412
20190316 155420
Reactions: 500oneer
jwfirebird
jwfirebird
927
1,446
western ny
I think you will be happy, no one I know liked the big horn for thick mud but I think those will be a lot better
