P1000 Cummins Pusher's Ride
Image Image Image Image Image Image Image Image Image Image Image
Well I've drastically upped the ante. This time I wanted everything just right,but most of all I wanted nothing to interfere with adding or taking off any and all accessories, everything needed to be separated with a plug so something as easy as taking a bumper off doesn't require cutting and splicing, several factory Honda car harness plugs were used,all lights stereo equipment must be able stay on through the removal of roof windows doors ect,adding anything doesn't effect anything at all, everything clearly marked is user friendly and lites up, nothing effects anything from the ultra dependable Honda base unit, is fully reliable and totally waterproof,NO VISIBLE WIRES to snag on make windshield or roof remove ability bad or look like crap, double fused and dedicated relays easy to reach and labeled, no inefficient pod lighting to snag branches or effect future accessories,even spread 360 degree lighting to guide the way at the right time and automated so anyone can use with no problems with dead battery or complications (lots of people come up with us and I'm not stingy)and above all no clutter dependable and fun that works as if Honda designed. No easy task. Hasn't really been done before from anything I've ever seen. We didn't just throw a light on with dangling wires to a switch on a nearly 20k vehicle. Absolutely nothing overlooked and no obstacle that wasn't eliminated. All mounting hardware was either built or replaced with stainless steel,including all bolts, aluminum,powdercoated. Everything is soldered,heat shrinked,water mud and dust proofed,separate colored wires(34 total and diagramed) loomed,placed out of any danger,extra mounts created, ect ect ect...you can shake this rig from anything added without possible movement. Any hole has grommets and very well secured from both sides. Since I made harnesses multiple wires were eliminated and a large common ground was made off second battery so each unit doesn't have its own that will fail and be impossible to find. I didn't purchase something because someone else said it works or it was cheap or easy. Lots of research over the last 3 months.We bought multiple units of lighting and ran wires all around and tested the 1000 multiple times camping (real world) with multiple people through all kinds of crap till it was right then stated over made complete harnesses bought the right lights and hid as much as possible including running harnesses through the roll cage. It's now done. A total of 12 separate interior light fixtures totaling over 70watts and 27 separate outside fixtures totaling over 1500watts, 13speakers totaling 700watts,onboard compressor, 110v inverter,multiple USB ports direct to the stereo with charging specifically for iPhones(1 each occupant) 4 separate adjustable zones for the speaker system and lightning(everyone treated equally) backup camera automatically turns on as well as side lights and rear lights when in reverse(also shows front low view basically at front tires in the technical areas) interior lighting,floor light,and outside entry light all come on in its own dedicated corner with its own door, the switch lighting comes on with driver front door. Redundant systems that can shut off certain high drain accessories in sequence of importance until power returns back to the second battery(which is totally separate from main)Lots of work! NOTHING SKIMPED!! Well here's how...easiest to start front work back...
Lights
---Center front upper bumper,
168w 5d optic Osram 12in 60deg/30deg provides center penetration low. Come on automatically in high beam also with separate switch,very bright easiest to install highly recommend!
---bumper upper corners x2, 50w 7in Phillips single row 60deg provides great center/side view and are tucked very close and just behind the bumper so no damage occurs wires run through bumper and unplug
---bumper lower corner x2, 15w Cree led cob stripes,multiple color white/amber 6in. These function as daytime running lights and are white while key is on. If main power switch is on (I'll explain later) They are amber. Also flash amber as a turn signal and are tucked very tight with 1/4 in lexan cover for brush.
---lower bumper cladding x2, 24w Osram 5d 60deg for extreme side view, will light up from front to the tire nothing escapes this perfect positioned light that's totally recessed and out of the way say goodbye to those pods next to the windshield.
---lower windshield, 700w Osram 50in 20deg/60deg double. This is the curved bar to fit the front perfectly, be as tight and low as possible, providing both maximum straight penetration as well as awesome side light(again no pods) and totally out of the way. It is mounted via 1/4 in stainless custom mounts to the roll cage with an additional hidden center support for a very solid mount. No wobbly windshield mount here. You can take the windshield totally out or install a 1/2 unit when it's hot and it's so low it's never in the way even w/o window. This is a high drain unit and is third in line to automatically shut off if 2nd battery power dips below 11.7v
---inner fender lights x8,2 9w 12deg Cree rock lights per corner automatically turn on in 4wd or separate switch and really light up undersides for extremely rough terrain. They also double as part of the party lights(I'll explain later) with multiple colors.
---lower side lights x4, 2 each side Cree 15w 120deg are mounted in between the doors and lower rear step these are great at giving you light right up to the very sides are highly recommended cheap and easy. Separate switched but will also come on automatically
in reverse and 4wd.
---Upper roof side mount x2, Cree multiple color 36w 120deg. These are the only lights that require unplugged if accessory roof is removed. They come on as with side lights, and are part of the party lights.
---rear mount whips x2,55w 4ft Gorilla lights (best from all we've seen very tough) very bright multiple color separate switch also part of the party lights. View attachment 12566
---rear mount backup lights x4, Cree 15w 120deg. These are mounted to lower and side roll cage for maximum lighting. The work very well with backup camera(if you look close you can see me taking pictures in the monitor in the rear view pic) don't blind people riding behind you,light up sides extremely well and flat ass look cool. Works well while loading and turns on automatically when tailgate is lowered, in reverse, or rear camera switch is activated. (We had a single 72w Cree prior and it was always too much or not enough and was always in the way or covered by the rear window. These are always uncovered and great.
---door lights, 5watt Cree Honda logo lights up a Honda logo on each door that's opened. More cool then anything but does avoid puddles in the dark.
---under dash/rear box lights x4, 1 in each corner lights up entry per door and come on automatically also with interior light switch.
---speaker bar outer lights x4, 5watt cree cob strips. Each side comes on with each door opened and also switch.
---speaker bar inner lights x4, 3watt Cree are independent of each other and are designed as personal lights. They are mounted directly over head and provide instant light for anyone.
---switch lighting x14, each switch has instructional light that comes on with headlights or at dark with driver door opened.
---interior lighting comes on with any door or tailgate open
---party lighting turns on whips,side lights,and rock lights. It has a remote can be any color,flash, sequence and also has music mode which will "dance" to the music throughput those systems. This is also 2nd in line to turn off automatically if 2nd battery drops below 11.8v. Image Image Image
dale5740
dale5740
886
417
mt airy md
Something is wrong!! Email seller right away that's not right. One hell of a spot beam
yeah center looks good but sides don't!! but when I look at it they all look like they are lit up bright!!!
dale5740
dale5740
886
417
mt airy md
its the floods I don't like
dale5740
dale5740
886
417
mt airy md
maybe u can shine yours on a garage sometime and post a pic. I got screwed cause got them off ebay and took them out of the box tested them in the daylight and threw away the boxes etc Just my luck
dale5740
dale5740
886
417
mt airy md
actually now that I'm thinking about it the orange plug that comes with it was messed up to begin with I had to mess with the wires to get it to light up maybe just the center is lighting up and making it look like the sides are lit?
320,448
That comparison was done with the original fisheye optics with only the 5watt bulbs.the new setup is way way better and 7watt.
320,448
We leave the vehicles loaded after camping so we're ready to go the next week so it would be a bit till I could shine it on door but here's a photo of the light on at 3feet from the quad. You can tell it's already spreading very good. The center is brighter because of the 30degrees but it lights up the sides very well. That light works so well we use it all the time
Eltobgi
Eltobgi
4,599
15,186
North Dakota
CumminsPusher, could you post a photo of your whip mounts? I'm trying to decide on a future location for mine, and way to mount.
I just ordered a set today Xkchrome Led Whips with additional pods. Not re if mounts included.
Impressive work with the lighting! yours is by far the most impressive and extensive example of lights done right;)
320,448
Image Thank you very much!This is the basic setup pretty reasonable u would suggest this and use the license plate as mounting point to see where you would like it. The roof is the best spot but depends if you're going to ever pull it. If you already have a mirror the monitor can mount that way but for a very solid mount get a roll bar clamp from Honda and mount directly to that. There are better cameras but this one is ok and you wouldn't be doing any damage to the machine until you were absolutely sure this is what you wanted and of your personal placement
Which back up camera did you use?
It maybe listed in your OP, but I
didn't see it.
Nice job.
John
320,448
We really appreciate the comments. It took months of planning and weeks of hard execution but it's done and will last:) here's a picture of the mount. I apologize for the dark picture and dirty machine but it's loaded and ready to hit the dirt tomorrow for the weekend. One of the backup lights is just below that's what the black oval box is. The mount is very solid and the Gorilla whips take one hell of a beatin we didn't have as good a mounting bracket before as they were on our 700 prior and we try to tear them off every weekend. If you're in brush really heavy you'll want to mount them down a bit and we bolted a piece of rubber onto the roof where the hit because on the last rig the made a hell of a racket after hitting trees and brush. Good luck with them whips are a lot of fun and set you apart a little
Reactions: Eltobgi
Johnny_C
Johnny_C
303
143
Western N. Carolina
Is there a better one you can recommend?
I want to install one, but I have no
experience with them. $36 is affordable,
but I would pay more for a good quality
one.
Thanks!
John
View attachment 13211 Thank you very much!This is the basic setup pretty reasonable u would suggest this and use the license plate as mounting point to see where you would like it. The roof is the best spot but depends if you're going to ever pull it. If you already have a mirror the monitor can mount that way but for a very solid mount get a roll bar clamp from Honda and mount directly to that. There are better cameras but this one is ok and you wouldn't be doing any damage to the machine until you were absolutely sure this is what you wanted and of your personal placement
320,448
one.
Thanks!
John
That monitor has been money for us all I did was take it apart pull the factory mounts off of it mount the Honda clip and sealed it up real good with black silicone I pressure wash the inside of the machine With no problems I tried not to hit it but it still got wet so far so good the only thing I would suggest is a better rearview camera where would you be mounting it? I would suggest a flush mount in the roof aimed down but the depends on roof and if you planned on taking the roof off. The camera does unplug though. You could even mount one roof and one under bed for certain things pretty easy actually which ever camera gets power feeds the monitor you just connect both rca together and feed power. We have the 5 so roof is definitely better ours is just under the roof higher gets less dust up high you really never have to clean it down lower it does need cleaned more but not near as often as you would think. And also measure the space between your roof and the rear rollbar to see how much room you have behind it
Johnny_C
Johnny_C
303
143
Western N. Carolina
We have a P1k3, so I will need to
mount the camera on or under the
bed. I have seen where some have
mounted them in the tailgate, but
that complicates getting the power
wires out of it & where they need to
go. I just looked & maybe I can mount
it right above one of the tail lights,
but I'll see when I get it.
Thanks for the input.
John
320,448
Image Image
John
No problem however I don't feel like I gave you much to go off of. If you come across anything or need any ideas bounced around feel free I really do like doing this stuff. I've got a feeling one of these would suit your needs. Well good luck with the build and if you'd keep me informed on how well you like it if you would I'm curious how someone else feels about it.
320,448
Here are pics of the SSV Works speaker box from the 700 installed into the 1000 probably first true bass box in a 1000 because no one builds it yet so I guess I had to. It took quite a bit of work had to cut it in half to reinforce it as it was starting to crack out in just 9 months in the 700 not impressed but whatever fiberglass work is easy. Had to change shape and build custom brackets for the 1000 and installed all new nutserts so it could be mounted and pulled out quickly. It comes out in 5 minutes that's way better then the 700 that it was designed for. I had already took the junk "upgrade" speaker out (watt rating was a joke! Not rms!) to install the Infinity because it wasn't getting the job done and clarity was horrible! "If" I run SSV Works again I'll order it unloaded without speakers and install good speakers that hold up and save some coin. I then mounted it up close enough to the inside of the cabin to port it directly inside for a way better sound (yes that's a powder coated shower drain cover I searched and that '9724my needs the best). I put a 90deg up-spout internally so you can go through water darn near to seat bottom. I also Installed red led lighting into the port tube so it has an evil glow at night. We have a plug that goes in for lake crossings if needed so it's totally sealed up then. It's as solid as anything else on this rig totally overkill:) This all works well with the Infinity prv-350-1 because it has subwoofer controlling right from the deck and separate subwoofer outputs. It's a damn nice deck. All in all I'm sure this is one of the clearest loudest sxs's out there. Now powered by an 800 watt Rockford Fosgate amp and with the port on the inside it'll damn near rattle the beer from the holder.
Eltobgi
Eltobgi
4,599
15,186
North Dakota
View attachment 13633 View attachment 13634 View attachment 13635 View attachment 13636 View attachment 13637
Here are pics of the SSV Works speaker box from the 700 installed into the 1000 probably first true bass box in a 1000 because no one builds it yet so I guess I had to. It took quite a bit of work had to cut it in half to reinforce it as it was starting to crack out in just 9 months in the 700 not impressed but whatever fiberglass work is easy. Had to change shape and build custom brackets for the 1000 and installed all new nutserts so it could be mounted and pulled out quickly. It comes out in 5 minutes that's way better then the 700 that it was designed for. I had already took the junk "upgrade" speaker out (watt rating was a joke! Not rms!) to install the Infinity because it wasn't getting the job done and clarity was horrible! "If" I run SSV Works again I'll order it unloaded without speakers and install good speakers that hold up and save some coin. I then mounted it up close enough to the inside of the cabin to port it directly inside for a way better sound (yes that's a powder coated shower drain cover I searched and that fit my needs the best). I put a 90deg up-spout internally so you can go through water darn near to seat bottom. I also Installed red led lighting into the port tube so it has an evil glow at night. We have a plug that goes in for lake crossings if needed so it's totally sealed up then. It's as solid as anything else on this rig totally overkill:) All in all I'm sure this is one of the clearest loudest sxs's out there. Now powered by an 800 watt Rockford Fosgate and with the port on the inside it'll damn near rattle the beer from the holder.View attachment 13647View attachment 13648
Nice Work! Where is Amp Mounted?
Eltobgi
Eltobgi
4,599
15,186
North Dakota
In the box where it's totally protected
How about a photo of the mount. I'm considering locations for my installation and love photos. Thank you.
320,448
I don't have a photo of the amp mount but I simply drilled holes in the bottom of the box used small stainless bolts and mounted through rubber orings to stop vibration and to waterproof the holes.works like a champ and waterproofs your amp. We had this same basic setup in the 700 however without the port and we went through seat level water with tunes loud as hell(speaker sounds a little funny with water covering it though:)) this setup can handle about 2 1/2 feet of water without the plug and totally submerged with. Everything is totally waterproof and pressure washer proof beyond belief. I don't like doing things twice. Fiberglass is the way to go here however wood that's very well protected will work to. This hits so much harder then those roof mount units and it's never in your way. This whole system cost me about the same as overhead setup (we had that in our last rzr and I hated how you always had to have a phone hooked up to it and no one seem to be able to work it well you couldn't really add anything to it except what they told you to I swore never again) but it's as expandable as car audio. I lose a little storage but for a lot of our riding we have service for the other parts I'll bring our tool bag behind the rear seats.
Similar threads
