P1000 DIY Skid Plate Template
Pilotadam
Pilotadam
326
735
Pell City, Alabama
I would like to thank ctd power and bones for the files. I was able to locate some used uhmw from a local shop that installs it in semi dump trailers and dump trucks for free! I decided to just make it all one piece and made a front pair of front a arm guards too! I mounted the skid and still need to make the rear a arm guards and then get them mounted up. Thanks again guys!
View attachment 186134 View attachment 186135
How did you mount them on the A-Arms? I have been thinking about doing g the same on my SATV arms.
Haldog77
Haldog77
NTC's Mafia Enforcer (Ret.)
44,583
371,190
Bossier City, Louisiana
I was going to ask where did you find the UHMW-PE material? I just priced it at a local plastic supply house and it was $423.08 plus tax for a 1/2" X 48" X 120" sheet. That is some high dollar skid plates.
E
e_eversgerd
7
9
Illinois
I didn't get a chance yet but I plan to mount through an existing hole and also 2- 1" pipe clamps around the a arm and through bolt it with cup washers on the underside.
E
e_eversgerd
7
9
Illinois
The piece I got was used and free. The shop where I got it installs it in semi trailers to protect it from damage and help material slide out of the trailer. This piece had been removed and new installed again in a trailer.
Reactions: Haldog77
P
patpete
65
149
Alaska
If any one has a pdf could they send a copy to [email protected]. Also could I drop pdf of at my waterjet guy and they cut from it?
Mastabeta1
54
90
  3. Other Brand
  4. Talon R
Im still trying to get the template from someone havent been able to get a response back by here or email... Please help someone?
tjoreo
tjoreo
1,032
1,992
Southern Idaho
Let's see some pictures.
I'm in the process of making mine now. I bought the material and printed out the template. Just to find the time to get it done. Thanks again for the template. It will save alot of time.
TI722
TI722
111
650
IL
  2. Other Brand
I'm going to change the hole diameters and add the holes along the outside. off of the file you sent me I have a quote through Regal Plastic for $292 plus shipping. I'm guessing that will be close to $75 or $80. It will probably add a little extra when I add the other holes and I'm also contemplating just running it along the rock sliders and covering just a bit of the step and not going straight across right there. I'm thinking that has to fill up with mud pretty bad.
Reactions: Bones and Smitty335
TI722
TI722
111
650
IL
  2. Other Brand
3D models of what I'm 95% sure I'm going with.
Skid
Skid2
Skid3
