P500 Enclosed Trailer Build
116,544
Started on the cabinet, toolbox is secured so I can haul tools in it anyway. Plan to put a shelf in half way up and paint the inside before I skin it with diamond plate and hang the doors. No way it'll be done for the takeover.
Looks good my brother! ;)
193,621
Looking great , that's going to be very handy having all your tools with you !
You can finish it up when you get back from the Takeover, no need to rush it and screw it up !
Exactly. I'm impatient as it is and rushing it will just lead to problems. Not the biggest cabinet but leaves more space for cargo and will still hold what I'm looking to carry.
popeye
popeye
3,275
14,644
kapowsin, Wa
wish I had some pics to show of it, but cut some of my flooring at the crosmembers, and installed a false floor, to make for more storage in my enclosed. might be a little much for your project, but you might want to think about it. for us its a perfect place to hide some of the tools and gear that don't get used every time when when they are needed, they are allways there.
popeye
popeye
3,275
14,644
kapowsin, Wa
Some advice if you plan on camping out of it for years is to use a motor home memory foam mattress if you’re folding it up against the wall, they are thinner than regular mattresses, and all inflatable one go flat on you at some point. Spend the extra money now and you won’t ever wake up in the middle of a deflated air mattress “taco”
Reactions: Biteme and BWAF
Choogsbro
Choogsbro
CEO of Monkey Business
8,144
52,659
Monticello, Ky
Yes I've already done that.
Choogsbro
Choogsbro
8,144
52,659
Monticello, Ky
Stands up against front counter. It is a full queen 60"X80" . Inside of height is 7'
Choogsbro
Choogsbro
8,144
52,659
Monticello, Ky
4 2X4s drop in slots, 1/2" plywood board hinged in center. When not in use I stand the mattress on end against front counter, then the hinged board, then the 4 2X4s. Then ratchet strap across all to hold. Takes less than 5 minutes. Stop by and check it out at the TO.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,543
Central Iowa
View attachment 71450 View attachment 71451
What site are you in?
Choogsbro
Choogsbro
8,144
52,659
Monticello, Ky
#31 I believe. It is at the end of the backin sites just past the 3 cabins.
Reactions: BWAF
Deleted member 3748
C'mon guys... we're talking about @trigger here. It's a waterbed or it's nothin'.
