This entire route is very easy.Same place. Hembree Bologna store.
Don't go expecting much.
Just asked for a fried bologna sandwich.
Sorry to keep adding.This entire route is very easy.
Thank you greatly!Same place. Hembree Bologna store.
Do you have steering stops in your steering rack? I noticed you've got the HL arms. You can run without steering stops with forward arms, but if you apply power at full steering lock in diff lock you'll trash the OEM axles quick. Just ask @TripleB ... I killed one shortly after I installed the SATV arms. Replaced with a Rhino and never looked back.LOL thank you so much! I will hit you up if we totally lose our 4wd
I will have to brag on my wife some because last night we were discussing it. Do we claim warranty and potentially wind up down the same road again later or go ahead and purchase an upgrade. She said I think an upgrade is better. I said cool, the rhino 2.0 is $240. Her reply was OK we just need $500 then. I said it's just $240 for the one. She said we need to go ahead and replace both front if we are going to properly upgrade it.
You are correct! I chose not to install the steering locks. The machine has never been in 4wd lock while turning. I knew it would need nice shafts at some point and I would rather have kept the turning radius than installed the stops.Do you have steering stops in your steering rack? I noticed you've got the HL arms. You can run without steering stops with forward arms, but if you apply power at full steering lock in diff lock you'll trash the OEM axles quick. Just ask @TripleB ... I killed one shortly after I installed the SATV arms. Replaced with a Rhino and never looked back.
Thank you greatly!
Sooooooo...........🤔 I hate to say it but, PICS OR IT DIDN'T HAPPEN!!!!!!!!!
I was able to pull up the kml file thru Google earth on my phone and see the eternal flame trail to the himbree store. I have the other files downloaded and I am going to download orux onto the tablet this morning and see if I can make the two cooperate.Did you get any of that loaded?
Nice.
Glad you got to go that way today. No trail numbers on that side.
If you think that trip was long... you don't want to go to the prison.
We followed the way points you gave me in the map overlay download from the previous posts. We stayed to the gravel roads or green trails today. From the research we saw Tackett can get extreme. When orux crashed it kept our tracks and resumed them. The only wonky thing it did was erase our way point we made.I could have sent you tracks for Tackett, but this area is not for a single machine riding area.
I have used Orux on a handful of devices. And while it will crash occasionally, it has always retained my tracks.
Orux actually has a warning at first startup that says it is not perfect.
You mentioned that another trail map system. It is using Orux as well. And the map system is not that much different for this area.
