Today I installed a glove box behind the warning plate .Used 3/8 plastic ,made the box 5 1/2" square ,cut 1 the shape of the indentation, and 1 bigger for the front of box, took the warning plate off, screwed the box on thru the rivet holes ,drilled 4 holes and cut it out with jigsaw ,leaving enough across the bottom to screw a hinge on.Used hatch hold down off a boat to hold the door shut .Can't even tell the glove box is there, Will work good for phones ,sunglasses' and billfold.
Kool. Sweet idea. And fairly smart too.
There is lots of un-used space behind there.
Someone could make a drop in box for cheap if they had the connections.
Thanks for sharing.
Thanks,also look at Choogin's Homemade glovebox,he did a great job on his .If I was doing it again it would have been wider inside,there is plenty of room behind the dash.
