Multi Hondasxs.com member safety mods
13,375
65,260
I went retractable for two reasons:
The manual Harnesses are a slight pain and I would be tempted to not use them for short distances or only use the lap portion.
The retracts for the harnesses are mounted where they need to be mounted.
So far they have caught when a sudden movement or shift initiated them to, but not when they aren't needed like the seatbelts on the 700, which if you were going slightly downhill they would activate even without a sudden movement.
I do like your setup. If I didn't already have the harnesses and bar when you showed yours, I might have gone that way as well.
You had a skilled welder help install yours. Not everyone has one of those a short phone call away.
I am not confident enough in my welding skills yet to do that myself. I would definitely hire that part out if I chose to go that route.
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
I have seen lots of talk of harnesses.
I agree with changing out the factory 3 point for a 4 or 5 point setup.
We need to put our heads together collectively and come up with a solution for the shoulder straps on the BCF bar. They need to be retained to do their job. I have a solution in place right now, but I want to get another ride or 2 under my belt before I suggest others do it as well.
So, Anyone with harnesses currently installed and the shoulder part not being retained from sliding on the bar, step up and help us come up with a solution to keep them from sliding left to right.
There is a lot of racecar science that goes into angles of retention and mounting locations for harnesses.
If the shoulder harness is free to slide left to right on the bar, in a rollover, flop, cartwheel etc, they will slide on the bar, potentially causing more injury than the factory belts due to compressing your body unnaturally, or not holding your body in place at all.
I would hate to see someone install a harness setup and injure themselves due to sliding on the bar, thinking they will be safer.
Can u use a 2 pcs shaft collar on the outsides of each set of belts?
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
29NX76 AS01
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
Work perfect
Upload 2019 2 12 10 15 3
Tusk Safety Harness Retainer Straps
Ones I ordered Pro Armor Safety Harness Retainer Straps
13,375
65,260
Did you look in my machine thru a time portal or something?
I am using 3 per side right now. one in the middle, and one on each side to retain. I haven't gotten the belt quite tight enough on the BCF bar to keep it from slipping over the collar. My next step is slice a piece of 2.5" OD .065w tubing from my scrap bin and tack that onto the collars to retain it.
Until I get that done, and can contain the belt 100%, I didn't want to share. But seeing that you brought it up, I figured I would share what I have done so far. I'll grab a picture tonight.
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
Do you have pictures of this installed?
I can get one when I get home, it works good though. Because I only have harnesses on my side I took the other one and have it clipped on a bar that I attached a few things too - neither has moved as of yet but I also have not been in a accident - it helps keep the harness straps in the same place and I also used prior to getting the harness bar.
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
Bought tabs and welded in nuts. U could also just bolt through the bar.
20190212 104147
320,082
If I did multi point I’d do this setup. Seatbelts don’t work unless they remain tight and most multi point I’ve been in it’s hard to reach things and be comfortable to drive. Biggest reason I haven’t switched out is we have so many different sized drivers, it’s not just me and multi is much harder to adjust and be comfortable especially with dirt or mud so I’ve been concerned people won’t spend the time to tighten or simply not wear them which would be much worse. I’ve been watching your setup and may possibly do something similar.
7,145
27,187
Retractable would best for multiple size and shape of occupants. If we can come up with something, I will contact BCF and see if he will add retainers.
Kilo427
Kilo427
1,543
6,439
I have worn the retractable ones in my friend x3. While I agree you can reach more with it I found my self continually yanking on the shoulders harness to lock the straps when going down big rocks and hills and up the more treacherous stuff. For just day to day riding its fine though. I just prefer to not move, I find its less aggravating on my back as well when you are solidly in a non moving harness as your core doesn't have to compensate.
Kilo427
Kilo427
1,543
6,439
As far as safety goes I try to keep my whits about me for the most part given my medical training. Also small first aid kit, usually an epi pin. You can carry as much medical gear as you want but depending on the situation in the middle of a trail there are usually two scenarios. Stabilize and wait for extraction or get off the trail for further evaluation.
I attended a wilderness life support once for several days. Was astounded how you must remove yourself from the typical mindset of sterile clean environment. Anesthesiologist was teaching us how to intubate with cut off car hoses. That tongues in the way well grab a safety pin and pin it to the side of the mouth out of the way. Because sometimes if your that far out if you do nothing the result is death so you have to try. But luckily most of our rides arent in such extreme terrain so far removed.
Although I did get to practice some skills I didn't know I had in Utah. Ask JTW, Hazard and HondaSxS
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
I have close on more than one occasion of purchasing one of these
Upload 2019 2 12 11 48 49
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
Aluminum fenderwell protection. @ohanacreek almost broke my foot in his rig behind my house with a stick coming through the floorboard. Just a Y shaped stick on the ground rolled up when driving over it and it went right through the overlap between the firewall and floorboard plastics.
IMG 20170416 220350804 Resized 20181017 233829
320,082
Great idea if needed. Were looking for a gps phone for awhile and @ohanacreek found a good deal on one so we went with that unit. Works good, we’ve only used it to say hi to friends but it’s always there in case the bad happens
