P500 Lightdow LD6000 WiFi 1080P HD Action Camera
  • Thread starter Deleted member 3748
  • Start date
196,414
Post....the Vid....
FWIW.....dangling anything
..off of front roll bar..
Bad Idea..unless you wear
helmet. .
IMO..
It's sitting forward of the front bar, no way you can hit your head on it. Have it in a rock solid RAM mount but still had it vibrating. Doesn't do bad with voices and low level volume but when you start turning it up it gets ugly fast.
rocmar
rocmar
4,741
5,778
4 CORNERS
Kool.
I know wat ya mean...
rocmar
rocmar
4,741
5,778
4 CORNERS
My go pro 4..
was like that...
took small piece of
rubber....wedged in corner
....it stopped it..
Reactions: trigger
Deleted member 3748
What kind of vibrating? Is it worse than mine? Are you using the waterproof case?
Reactions: rocmar and trigger
Deleted member 3748
Had it vibrating like a rear view mirror from the sub hitting. Didn't appear to effect the video much but I could see it on the little led screen on the back.
mine shakes a lot, especially when idling. See if your camera has a setting for image stabilizing and turn it on.
Reactions: trigger
