P1000 Limp mode, won't shift out of 1st
samson7x
35
61
Arkansas
I'm getting a 5-2 code. Anyone know what that means? I checked all fuses and nothing is blown. I turned it on/off a few times and nothing resets, remains in 1st only. My UTV is basically new, only 150 easy miles on it. It's a non power steering model if that makes a difference.
Thanks for your help.
13,364
65,124
@samson7x ,
Would you mind posting a video of your dash flashing the code? I didn’t see a 5-2 under dct or pgmfi.
samson7x
35
61
Arkansas
@samson7x ,
Tried to upload but file too large. When I crank the wheeler and while still in park, the number 1 pops up in the “gear” section. It blinks 5 slow followed by a short pause, then 2 fast blinks. Does that make sense?
13,364
65,124
@samson7x
Your 5 slow count is equal to 10 per. 5 count is 50, and your 2 count is ones,
The code you threw is 52.
Check a few connections, if you are into a pcm replacement, send it back to your dealer.
48E3D669 4B09 4731 A604 1F29104EA6A5
54CBD47C 0FB9 4F93 A783 361523DE5610
Deltamud
Deltamud
100
70
Florence, MS
found that if the neutral indicator switch does not make contact the pioneer will only run in 1st gear in safe mode.
In safe mode the engine tends to lope a idle. I learn this first hand at week one when a rat decided he liked the taste of the wiring.
samson7x
35
61
Arkansas
Haha, have 2 dogs but they are worthless.
Wire reconnected and all is well, but how do I get the maintenance wrench light off now?
Reactions: strongbuilt
strongbuilt
strongbuilt
260
606
Hold the button on the odometer and turn the key on and off twice
208,013
Get a Jack Russell, no more vermin issues!
rasorbackqq
14
14
Springfield NS Canada
  1. Big Red
On a side note we had mice eat a wire from a Accent wiring harness last year $3000 under insurance . We were told its more and more common now with all the soy based plastic on wire coatings.
samson7x
35
61
Arkansas
Interesting. Well, I got the bastard that messed with mine so he won't be chewing on anymore wires. Also discovered that he chewed my neoprene waders, half box of shotgun shells, and an ice chest. SOB cost me quite a bit of money....
265,578
Based on the codes, it is likely not reading the gear select position correctly. Could be from not firmly putting it into park or neutral etc. Could be the cable system actuated by the shift lever needs adjusted, and finally might be the sensor that detects it to be in park or neutral to start.
Might just try shifting the lever around making certain it is fully engaged in each location. Even try starting in H by putting foot on brake pedal when turning the key.
Also if seat belt isn't latched it will not go out of 1st gear limited to 15 mph, safety feature.
Mike129
Mike129
125
240
Iowa
Recently installed lighting, 2nd battery, isolator, bussman PDM, switch plate... Etc. Since then my pioneer 1000 has gone into limp mode a few times. I have the rear lights hooked into the reverse trigger and also switched so I can turn them on whenever I want also. Have a 52 inch light bar, interior lights, winch and rear lights on aux battery. I figured out today that when I turn the rear light switch on, the engine light begins to blink and put the machine into limp mode. I can run the other accessories without issue. Had a friend help with the wiring since I am pretty much illiterate when it comes to electrical work. Any ideas for me before I start tracing wires?
elkaholic
elkaholic
Illegitimi non carborundum
2,097
8,601
Ridgeway, SC
When you switch on the rear lamps, you are likely somehow backfeeding the ECM and it sees an indication of being in both reverse and a forward gear.
Reactions: Neohio
Mike129
Mike129
125
240
Iowa
Make sense. Ideas on how to fix it?
W
wyodlr
147
209
Cody Wyoming
How did you wire the manual switch ? You should just be switching the ground.
Reactions: lee
