P1000 mjn's build thread
212,679
I
View attachment 101684 View attachment 101685 View attachment 101686 I decided to make use of the 24” dual row Rigid bar I took off the Viking. I was gonna do the 52” across the lower windshield... and still may sometime. For now though, this one will work fine.
I looked at a couple different ways to mount it, and came up with this today.
A severely tweaked pair of short bars I had in my toolbox, bolted to a bar clamp.
Looks kinda ghetto right now, & I do have a little more tweaking to do on one of em...
But here it is.
I drilled some holes in the well where you mounted your isolator for mine so it wouldn't hold water.
mjn
mjn
1,409
5,206
SE Washington State/N Idaho
Also changed out my OE battery. It had an internal issue of some sort. Picked up a Die Hard brand battery with 220 cca. Works great!
Something is strange though.. where my volt meters previously hovered around 14, now they both display 7.5-7.9....
Is that correct? We’re the high readings before because the battery was weak?
Reactions: CumminsPusher
Thanks man, I hope it looks as good as I envision when it’s powder coated, but regardless, it is STOUT.
Stout is good!
Reactions: BWAF
mjn
mjn
1,409
5,206
Okay, found my electrical issue.. I had neglected to hook the ground wire for the panel back up.
I decided to take this time to tidy up the underhood wiring a bit. Also finished installing the relay & wiring for the underseat fan.
Lookin a little cleaner under here now.
mjn
mjn
1,409
5,206
Finished the fan install today.
I decided to use light weight aluminum angle.
First, I cut a piece for across the top. I put a 90 at the end so I could attach it to the frame there too. I used a Chevy u-joint cap to attach the angle to the round tube.
Next, I made a box around the fan, added a support on the bottom so it would stay where I put it.
All in all, I think it turned out okay.
3166F6D8 2F66 440B 9790 C564CDE1BA91
077DB754 8ABB 4B23 9745 7CC2CB9D0FF1
1BD62C62 772E 453A A6BA F62EB9161EBB
4D1F38D3 EC00 4E13 9FAB 983D912FEE95
B64E91EF 2289 4390 93C4 FFA1EC8FECF8
mjn
mjn
1,409
5,206
I obviously have several months before I can tell if “just” an 8” fan will cool the seat bottom enough.. but I’ll report back when that time comes.
I’m still looking for the right vents to put in so the heat can go the other way(into the cab). When I figure out which vent fits and works properly.. I’ll let ya know.
BWAF
BWAF
I get paid to pass gas
8,869
42,496
Carthage MO
My 4" bilge is night and day, it will
Nice job on install. Ya that’ll be a little bit around here till it’s needed lol.
212,679
I bel
I believe it will, thats what I have and works great, thinking about removing the seat insulation for winter heat.
Similar threads
Replies
Views
494
P1K5Dave
V
Replies
22
Views
2K
Jankyeye
Replies
65
Views
8K
P
Replies
Views
3K
