P1000 NBomars tinkering and silly stuff
nbomar
nbomar
4,416
17,855
Springdale, AR
What happened to her Jeep?
Front hub bearing was really bad. She said she would drive home but I didn't want her stranded. We decided best bet was just haul it home so she can get it fixed in the morning.
Reactions: CumminsPusher
211,097
Great judgement, even from you. HA!
Reactions: nbomar
nbomar
nbomar
4,416
17,855
Springdale, AR
8400cd15b860688ab48178e4a4e3755f062cb46ac2e65409d8f40de2d95a617613a5cd88387e177ea305f5791bdbb832
I don't ride that much mud, but after the takeover these were a must. I thought the back would be like @joeymt33 but I guess @mudbusters didn't go with that design? Either way, simple install and I can assure you it's worth the money. I also got to put anti seize on the back wheel studs. Almost gave myself a hernia trying to get the studs off. It's bad when your snap on impact won't budge them... fronts were already done and they come off like butter. If you haven't put anti-seize on your studs your asking for trouble...
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
View attachment 43121View attachment 43122View attachment 43123
They have to different styles of rear flares. XL and standard...The xls go around the ROPS bar
Reactions: sharp and joeymt33
nbomar
nbomar
4,416
17,855
Springdale, AR
E6722cd72033dd1d5528d0377e996f16A9f42807effb22af3d986ada4fcc63dc
Looks like my rear tires are leaning in? No weight in the back right now. Cooler is empty. Don't see anything bent at a glance? Any ideas?
I swear I have a motormount or something loose cause the motor the slap the bottom of the floorboard, but I can't find it.
32ded34f83248cffb5ca3c3b0d49319a
Put mudbusters on this week and now both front tires rubbed like crazy on the asphalt. Drilled a couple holes and a few zip ties and all is good again...
nbomar
nbomar
4,416
17,855
Springdale, AR
View attachment 43506View attachment 43507
Oh yeah... I also realized that my bilge fan was mounted backwards. I know at the takeover it didn't do much to keep us cool. In fact the seat got hotter the usual. Misty even commented I hope you didn't spend much on this... quick cut of the zipties and flip the bracket and all good now. Probably makes a lot bigger difference now that it's blowing the heat out and not blowing it on the back of the front seat...
sharp
sharp
3,757
14,955
Tennessee
You might just now be noticing it. They all do that. You would rather them lean in than lean out.
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
I hate to laugh at someone's misfortune but that's pretty funny.
