280,333
Nfjffm1eox9qito ajfush dbu3mm8uxtnlbv6wkc7wd4rxnhyxikfx5jvrxxbxyzwenfo90y w548 h935 no png16190
Why is the 4th file extension named North Cumberland trails.TBD instead of North Cumberland trails.TYP ? That one thing I see different. And I don't even have a file named 11111212.img something is screwy with your file names. Where did you get them from?
LandPioneer
LandPioneer
929
2,417
Lebanon TN
FYI, anyone reading this Jackal was right. Rename the .TYP file to North Cumberland Trails v2.3.typ (instead of 23NCumbe.typ) and the trail colors will work. Both files have to have the same name, one being a .IMG file and the other being .TYP.
Reactions: JACKAL and Hondasxs
Is there a reason the GPS function isn’t working? Before I get to far into this, I figured I better ask. I’m clueless when it comes to Android. Has there been some kind of change on the new kindle fire hd 8’s that won’t support this app anymore?
531F0312 970C 4A84 A9F6 9CBFC89B8F7C 4ECE8517 C79F 4CB6 B627 57832F638701
I went to the kindle loaded map app and the GPS is working properly. I even loaded the previous version of oruxmaps to try that. I don’t have google play installed yet as I’ve just started messing with this. Any ideas?
280,333
View attachment 56221 View attachment 56222
Did you turn the GPS tracking function on within the app itself , Upper right hand corner little pop up menu are the top 3 buttons
280,333
Also after you turn on GPS tracking then you can enable GPS logging were record your track and you can save them delete him etc. for a each time you go out as all control within the menus on the upper right corner this have to read the PDF file on the user Manual
Reactions: Ragnar406
280,333
Sorry I'm not much detailed help right now I left Maryland this morning on my way to Arizona and I won't be home until Wednesday I left my tablet there.
jinx
jinx
565
528
I'm not certain kindle fires support GPS with all apps (or at all) anymore
The whole Amazon vs Google vs Microsoft vs Apple kerfuffle makes the world a pain for end users sometimes
Reactions: JTW and ohanacreek
280,333
280,333
Looking at your screenshot, you need to close all apps. Then go into settings, the gear icon, then select device, there all hardware options should be available (screen brightness, GPS on off, etc.)
It's not the program, the device has it off to save battery power and privacy settings.
knuckledeep
knuckledeep
my trailer queen is trashy
1,052
3,470
Eustis florida
Does the kindle work good or is the samsung tablet better?
280,333
I'm pretty sure Samsung manufactures the Kindle for Amazon. Just like the iPhone's, even thought Foxconn assembled them most parts are actually manufactured by Samsung. It's really the software that sets them apart, on the 8" models the Sammy and kindle have the same screen resolution. For GPS purpose each is 6x overkill powerwise. So really boils down to battery life length and what makes you feel better.
Reactions: Landman
This is what I’m afraid of..
Reactions: nbomar
280,333
All you have to do is install the Google play store on your kindle and it will tell all apps on there for android watch the YouTube video I linked .
Reactions: JTW
I’ve got everything on and and when I try to turn the gps on within the app I get
0EBA8301 3BB6 43FB B7F3 FE689CFB1A15
But the thing is I have the oruxmaps app turned on for location services.
I’ll try that when I get home.. I attempted google play last night but was prompted I couldn’t for whatever reason
280,333
I address at last night my reply you're probly have to go into android itself in the settings in enable the GPS chip probably has it turned off to save battery power.
280,333
Location services is the only option I have for controlling gps features.. I've gone thru the whole settings menu. So I have everything I can find on the tablet to allow for outside apps and location (gps) functions.. On.. But when I try to turn gps on in the oruxmaps I get the prompt. So is that where/why Google play is needed?
