BOX1
P1000 P1k and talon ecu swap
GPR1500SC
GPR1500SC
856
2,350
North East MO
  2. Talon X LV
I would be interested in that setup but I don’t really care for more power top end so would doing all yours except the AT cam be beneficial?
I think reflash should be the first mod and the camshaft is the second key to unlocking the real horsepower the rest are really supporting mods.
Snuffnwiskey do you want to chime in here?
Reactions: JTW
I’m just sitting here waiting for @snuffnwhisky to tell me what to do... ecu flash is next. Maybe injectors depending on what’s needed fuel wise.
Reactions: joeymt33
GPR1500SC
GPR1500SC
856
2,350
North East MO
  2. Talon X LV
Basic mod order if I modding a stock machine
Enlarge the stock throttle body to air tube adapter and exhaust outlet elbow.
Then second do a reflash
Throttle body
Then the camshaft
aauman88
aauman88
1,091
2,846
I have HMF Titan exhaust and PCV installed. Just looking for next logical step without just throwing money at it. Also have my buddies in my shop that is bone stock performance wise we are looking to upgrade. We both have large mud tires and play in some serious mud holes and just looking for more low end power to help turn the tires.
GPR1500SC
GPR1500SC
856
2,350
North East MO
  2. Talon X LV
You got the exhaust side freed up now you need to enlarge intake side the stock throttle body to air tube adapter need to be enlarged the stock Pioneer throttle body is 44 mm but the adapter chokes it down to probably about 40 mm.
All the changes I made on the machine the three things that made noticable HP where Talon ECU, African Twin cam, and the Talon throttle body.
The rest are improvements but did not give that OH YEAh that's what we are talking about feeling.
Reactions: Plumber32
aauman88
aauman88
1,091
2,846
Thought you had Talon ECU?
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,150
Cullman, AL
  2. Other Brand
IGR is your best bet if in the mud or rock crawling.
39,078
That’s where I’m at too. Just waiting for what comes out of the “village idiots” speed shop
aauman88
aauman88
1,091
2,846
The throttle body is a plug and play mod
But you need to bore out stock throttle body to air tube adapter or buy a Talon adapter, or a Honda Talon Aluminium Throttle Body Adapter | eBay
Let me do a recap on my mod list
A/T cam and air tube adapter
Cat removed from stock muffler
3/4" hole drilled in muffler
Dual spark plugs
Power Commander
Talon ECU
When you install a African twin cam you loose low end torque and gain top end horsepower,you add Talon's ECU it gives back low end torque but leaves a soft spot in the middle. Installing the 46mm throttle body and injectors eliminated the soft spot in the middle.
I doubt a stock Pioneer would see much benefit without supporting mods:
Cam and Zmorris reflash.
That adapter made for Talon will help and bolt on my pioneer?
Z
Zmorris83
Cam and tune are ALWAYS the top 2 for any mass production, emissions certified vehicle.
Z
Zmorris83
You lost me? What do you mean by generic and full tune?
Timing, fuel, and speed/RPM limiter.
That may not be generic to some, but when I'm accustomed to vehicles with 100s of maps that is extremely generic. The Ford PSD I did Saturday had 855 potential maps. That doesn't include any switches or scalars.
Reactions: GPR1500SC and JTW
Z
Zmorris83
I got my reflashed eco back from Silber turbo and put it on yesterday. I'm not seeing a big difference so I called Justin at silber turbos and he asked me if I was the one that sent the new computer to him, he said the computer will go through a break-in period because it is new so it should get better. I can see that the rev limiter has changed.
o_Oo_O
LMAO, tuning maps are changes in code. 1s and 0s don't "break in". Maybe if only the target was changed, but that would be a really dumb way to tune.
MReihl
Mid Michigan
Depends on what you want. 200 if it's the generic crap everyone else is putting out. 300 for full tune. I'm not interested in tuning them commercially but I'll be happy to help the forum members out. If we can keep it to popular setups that would help save me time that I don't have. The only reason I even developed tuning for the Pioneer and Talon is because I wanted to tune trans/clutch in both of my own machines.
I am definitely in for a full tune whenever you get it all figured out.
If I knew anything about hexadecimal, I would be more than happy to help. My experience is limited to changing timing and fuel using FTecu on the YXZ I used to own, so I basically know nothing.
Z
Zmorris83
If you're wanting more bottom end, me and GPR1500SC are working on a cam profile for that. Something closer to a Pioneer on bottom, possibly even more bottom end, with more mid-range and some extra top end. Works with Talon or AT springs/retainers.
If you combine it with IGR and supporting mods would probably double bottom end.
Reactions: Tigermark and JTW
jtucker
jtucker
118
118
North GA
I may be stupid but what is IGR
Z
Zmorris83
Honda OBD2 Harness Type 1
This cable, a J2534 compliant interface like the 10$ ELM327 and the $5 Torque Pro app should datalog if y'all are interested. $53 is crazy cheap for datalogging.
I know Innovate Logworks OT2 and LC1 work on K line. If you want to add Lambda (and a lot of expense) that is the best option I know.
Does that output speed and tach over the interface?
BOX2
box3
