P1000 PIONEER DYING WHEN PUT IN GEAR
ArkHog10
ArkHog10
54
98
Did a search on here about this but didn't find much. The Pioneer will start up just fine but when I put it in gear it dies immediately Has anybody had this problem?
Reactions: Lady01
Gator
Gator
The Most Unknown Member
2,474
10,381
Louisiana
1. It's confused about neutral position
Are you cranking it in gear? Try cranking it from the neutral position.
2. Some other interlock.
I can't think of what safety interlock that would be causing this.
3. The clutch is locked up
If the clutch won't slip then the wheels are directly coupled to the engine. Does it lurch forward? Harder than usual?
Reactions: Lady01
13,346
64,911
Is it flashing any codes after it dies? Either the check engine light or the gear selection will flash. long is a 10 count, short is a 1 count.
Reactions: Lady01
ArkHog10
ArkHog10
54
98
It will start in park and neutral but when I put it in drive or reverse it dies. I don't think it has to do with the clutch.
Reactions: Lady01
ArkHog10
ArkHog10
54
98
I'll check to see if it's flashing any codes.
Reactions: Lady01
0
0860silverado
945
1,813
louisiana
Maybe let the engine warm up a while. When I first start mine in the morning, I can put it in gear and then accelerate but I can't stop without the engine sometimes stalling. Almost went through my garage door a couple times! My first gear clutch sticks in the engaged position until the engine warms up a bit then it's fine the rest of the day. Did that since the day I brought it home new from the dealership.
Reactions: Lady01
Sloganuga
16
14
Leesburg, GA
Same thing mine was doing in addition to other issues. It’s at the shop now being diagnosed, but initial word is it’s related to the tranny.
Reactions: Lady01
63,541
Key on. But NOT running.
Put it in D, R and L. Does the display show correctly in each spot?
Or is it a -- .
Thanks.
Reactions: Lady01 and joeymt33
Does the oil pressure light illuminate while running or right before it dies? I had a similar issue with one, ended up being the shift drum weren't center bolt had come loose. But it could also be clutch locking up or a similar problem.
gullyjumper
gullyjumper
950
2,413
cookeville tn
I know it sounds weird but my jd mower would start fine but when I would engage the blades and try to move it would shut off. So I went to the dealer told them the problem , long story short it was the battery. A new battery and no more problems.
Reactions: Lady01 and CASTRATE
BDickinson1969
Maine
I have a 2016 pioneer 1000 that starts great idles great even revs up fine in park but once in gear and riding it starts cutting out at half throttle any ideas
Reactions: Lady01
13,346
64,911
Is it throwing any codes on the dash?
If it is, video it with your phone, upload to youtube and link the video for us to help out.
Reactions: Lady01
93whitese-r
93whitese-r
55
Cincinnati ohio
Replace the spark plugs mine just did the same thing would run in park no codes and would die if put into gear... Must have fouled a plug or something from not letting it warm up
Reactions: Lady01
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
Have u modded any electrical? Reverse buzzer and neutral switch will kill it like that.
Reactions: Lady01
