P1000 Power commander V
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
As opposed to "fake" air?
More like fake real world conditions. Haven't heard of a cell yet that could simulate being outside. The jist of what I was saying is if tuned for max performance on a dyno, it's gonna be on the lean side running down the street, or track, or trail or whatever it is you run down lol.
Reactions: Plumber32
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
The bad....
We found out as you can see in the video above that we could only perform a very short pull in first gear. This sucks because HP will look like it's ~20% low and torque very high. Also, it doesn't really put the engine under a load to see how well it's going to perform. Another bad thing is the pull is so short, you don't have much data to see the peaks and troughs.
There's a speed sensor in the front diff. If it's not turning, the puter won't allow it to shift. So, now we've got to figure out a way to "trick" it or do a pull in 4x4 with the front wheels off.
I'll let this soak in while I type up the results.
That explains why mine wouldn't shift while doing donuts out in the cow patties (actually horse patties). Now we know.
Reactions: sharp and joeymt33
69,906
Just playing with you
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
When we got back I put mine on the lift and tested the shifting. It will shift in 4wd. After a 4wd test, it would let me shift into 2nd only in 2wd. Think we will need a cable to tie the front vss to the rear vss to get it to work.
Me and @joeymt33 hit up the dyno today. I'll let Joey gush about the results! Left my brand new virb there...:mad:
You're going to regret letting me talk about it!
Next up was the super fast and sexy Traveller.....
First pull was with with the mostly unmodded tune from PCV. I had richened it up at WOT throttle and leaned it on the low end but the meat of the map was unmodified.
1st. 47.78
For the next dozen pulls or so I didn't take good notes but we played with the target AFR and in short, we found that we got the best results with 13.0 AFR. We tried 12.8 to 13.3 and we could see a couple HP difference in that range.
Also we played with ignition timing and left it at 4° advanced in the meat of the map and 6° at WOT. PCV had it set at 2 and 4. There is still work to be done here but we could see ~2 hp difference with that as well.
On the last two pulls (last pull isn't shown) we got repeat 49+ HP. Looks like with proper tuning the engine will get a little pick up. I am very satisfied. Also, I've got to say it. My butt dyno looks to be very accurate!! I predicted 8hp and it appears that at the fly wheel we could've picked up more than that. It would probably be 8-9 if we could pull in third gear. There's a lot of HP loss in that low gearing.
Other note, I was running 87 non ethanol. Next time I'll run 93 and see what happens.
Eb61ea089ea67fb163042abed16d697c
One cool thing to notice. Check out the torque numbers. They are totally inaccurate because of the low gearing. However, it does show that there was a big difference between stock and tuned. I'm sure that increase in torque especially on the low-end is what makes the pioneer feel much better out of the hole after being tuned.
GPR1500SC
GPR1500SC
861
2,426
North East MO
  2. Talon X LV
The bad....
You will have to pull the front axle shafts next time
GPR1500SC
GPR1500SC
861
2,426
North East MO
  2. Talon X LV
did they program the gear ratio in the dino? if they didn't I think you need to divide the torque number by your gear ratio to get a actual number?
We weren't too concerned with getting an accurate number to compare to a what Honda has. We just wanted to see the difference in the power commander. Hopefully next time we will be able to test a couple different snorkels and the exhaust tip.
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
The gearing was to low to get any consistency on the torque numbers. But you can tell the difference between the 2. Like I said when I drove joeys it was a lot more responsive that mine down low. Once we get the shifting issue and my programmer on, we'll go back and get better runs in. Main thing is the programmer definitely helps, a lot more than I thought it would. Sucks I've been staring at my programmer for a few weeks waiting to get a baseline on the dyno. I've got this to test when I get mine hooked up.
1488690685898572100770
69,906
When it gets to complicated motor work i turn into a brick. But im very interested in this seems pretty simple. Very interesting as long as theres no loss of reliability. Which I assume theres not since the bike is 120hp.
Reactions: CumminsPusher
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
If it showed that kinda difference in torque with 1st gear pulls, imagine what it'd look like at 1:1 pulls. Wow totally impressed here. I was huge skeptic at the start of all this. And now eating my words lol. But this is one of those times I don't mind being wrong. Torque is something these pigs could use more of.
69,906
Where is the @drfubar ? Must of fell of Marys ridge! Lets make sure @joeymt33 isnt peddling these power commanders on the side first!
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Dang he sells one defective p700 and y'all peg him as a snake oil salesmen lol. I'm pretty sure I can trust him (still gonna keep my one good eye on him though) lol
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Staring at unfinished projects is all I've been doing last month or so lol. Just not enough time to get around to all of them lol. Anxious to hear what kinda results you get out of that intake. I played with ram air on my dragbike few years ago. Alot harder dealing with carbs though. I got some serious mph gains with it but it ran like crap at lower speeds.
