P500 Power steering
Chooglin
No, the motor unit. P500 - Power steering install. Think @trigger has a similar problem with motor install. Don’t know how similar the Tusk is to the EZ steer motor.
Thanks for the link !
Pretty sure I have it mounted correctly , I never removed any bolts from the motor (13mm you speak of) I used the 10mm bolts in the box. So it can only be mounted 1 way , provided you don't remove those 13 mm bolts !
Chooglin
Yeah, they showed the motor upside down in the instructions which caused some grief. Once i got that figured out it was pretty easy. Need to loosen upper shaft and turn both ways full lock, find the happy spot in regards to motor flex, then cinch it down. Still flexes a little but Superatv said that was normal due to limited space and short shafts. Haven't had a problem with mine since install.
Everything seems to work fine , I did notice the flex you are talking about but it is very minimal!
Chooglin
No more steer shock or endless hand over hand in the tight stuff. You're going to love that upgrade, enjoy! :cool:
Thanks @trigger and @Mudder for the tips!
I am going to love it and I am sure the wife will appreciate it too. She hasn't tried it out yet but she will thank me , I'm sure.
I did have to pull the steering wheel and line it back up , after the install.
HUCK
HUCK
1,047
2,315
ARIZONA
If you need power steering on a Pioneer 500 maybe you should get a girl to chauffeur you . :D
Reactions: Gassygordo
GRANITE
GRANITE
People Dying to come see me!
1,100
5,550
Brookville, Indiana
Well, an update from me. Since SuperATV is so close to me and I told them I can get the Tusk unit cheaper they are installing it for free for me and discounting it as well. I dropped my P5 off to them on Saturday afternoon. There warehouse is unbelievable with all their race rigs and monster sxs's..
NTCPrezJB
NTCPrezJB
President of #NTC
101,503
906,840
Canton, OH
I don't need most of the sh** on mine but it's nice to have. :cool:
hahaha....I can appreciate that statement. I say I "need" something for it. The wife quickly reminds me I only "want" something for it, just like I "wanted" the machine to begin with.
Chooglin
@Mudder and @trigger have a look at these pics ,does it look to be mounted correctly? I also took a pic through the drivers side fender !
20180226 162436 20180226 162323 20180226 162253
HUCK
HUCK
1,047
2,315
ARIZONA
That's the crucial word "need" not at all to be confused with want lol .
I think about p.s. almost every ride just because its the in thing (all the cool guys have it) but I just can't convince myself I would appreciate it .
158,622
158,622
The PS was worth it to me, something used every time I'm behind the wheel whether plowing or trail riding. I'm just hoping to get as much satisfaction out of the shocks?
GRANITE
GRANITE
1,100
5,550
Brookville, Indiana
Yes I’m thinking WE shocks on the front myself...hard to swallow $1200
11,352
84,496
@Chooglin , looks like big round part faces down, looks good to me. Wish I did the PS from day 1.
Reactions: Chooglin
Chooglin
Thanks for the replies guys !
I downloaded the pdf instructions from superatv site and I think I found the pictures that you guys are referring to. These pics look nothing like the pics on the instructions that they sent me in the box. This pic is way wrong , just like you guys said.
Screenshot 2018 02 26 16 59 18
11,352
84,496
The SEARCH feature on this forum is something I use offen, usually can find good information. This thread is a great example to help others down the road. @Hondasxs has saved me from many headaches, and provided good “gotta do that mods” during P500 ownership. Working together.
RumpRocket
189
295
USA
When installing the power steering unit did you run the + an - wires to the battery box?
158,622
To the solenoid and then yes all the way back or to your power block. Nothing on that machine will draw more power than that winch and you don't want to starve it at all.
Whoops, was just reading a different post on winch. Disregard that last post.
As for the PS, I ran mine back to my power block also.
Reactions: RumpRocket
RumpRocket
189
295
USA
So you do run separate wiring to the battery?
