P1000 Project "Snowball"
Superthrill
667
1,558
North Carolina
20190329 091348 600x800
Superthrill
667
1,558
North Carolina
So did you do the other side to match?
Not yet, got to go have a flat on my trailer replaced right now. Going to this evening though. Wished they made a round half tube piece of UHMW!
ToddACimer
ToddACimer
Pioneer 1005-2
3,813
16,234
Oshkosh, Wi
Wouldnt be that bad with a heat gun
Superthrill
667
1,558
North Carolina
I got some 5/8" thick UHMW. Thought about milling a channel and adding some
Reactions: honda12345
ToddACimer
ToddACimer
Pioneer 1005-2
3,813
16,234
Oshkosh, Wi
That's a really great idea. Makes me want to cut my cage and then gusset the cut line just like that.
Superthrill
667
1,558
North Carolina
After the last ride, I decided to do something about the heat. Installed an 8 inch fan. Made a shroud to block heat from the radiator hoses. Hopefully it will pull from the leg area after I put in vents.
20190411 174234 600x800
Reactions: ohanacreek
Superthrill
667
1,558
North Carolina
Next came the shields for the radiator hose areas. I believe they are why your drivers area gets so hot. Added the aluminum tape to the back of the HDPE peices.
Before....
20190411 174246 600x800
Reactions: Rockydog
Superthrill
667
1,558
North Carolina
So, I think we need to pull heat out of the engine compartment instead of pressurizing it. Pull air in all the little places! So added the cooling vent for the flux capacitor to the hyper cooling drive.
20190423 172233 600x800
Sucks air from the coolant side of the block and vents it out drivers side.
20190422 174003 600x800
Superthrill
667
1,558
North Carolina
Finally got the rear spring spacers installed. Unloaded the machine was sagging in the rear. The springs had settled so all the top coils were touching.
Add all my gear or passengers and I hit every rock in the trail.
Added to the bottom.
20190423 172249 600x800
Superthrill
667
1,558
North Carolina
Also got the sway bar removed. Wheel spacers will hopefully be here this weekend . Pretty much done for the Takeover. Have to mount the spare axle somewhere and some rear mudflaps.
May also try to make a chainsaw mount.
Seriously doubt I will have time for some tree kickers...
Similar threads
