P1000 Synthetic Winch Cable
Scamih
183
464
Marshall Illinois
I bought a new winch, viper max 5000. I ordered the steel cable and I’m regretting it, I don’t like the way it winds up. I think it’s just got too much cable on it and in going to try taking 5 feet off. I’m eventually going to order a synthetic cable but I see a lot of reviews about them snapping and I don’t want to be stranded. Does anyone have any suggestions for an after market synthetic cable that will pull a 1000-5 out of whatever I get stuck in. There are a lot of options on eBay and Amazon. I would prefer to go with a proven one.
Reactions: JACKAL
I buy 3 at a time, one for each winch and a spare. I use the winches heavily around the homestead and occasionally on the trail.
Make sure you replace any fairlead youve used with the steel rope as any scratches or burrs will immediately damage a synthetic rope.
I’ve bought these since I’ve owned a Pioneer and haven’t had them snap yet, I do take care of my ropes though.
Russ989
Russ989
22,608
146,956
The amsteel blue ropes that come on the viper winches are pretty reliable, I have a viper elite widespool and haven’t had any issues with my rope. You need to switch sooner than later, as that cable pulls tights it will scratch up the drum which will shorten your rope life when you switch.
Russ989
Russ989
22,608
146,956
That’s cheap, I might have to grab one of those to keep as a spare.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
I've never snapped a synthetic rope and I probably don't take real good care of them. I maybe wash it once a year. Ill never own another steel cable. Frays, kinks, and the fact its a lethal weapon every time you use it. Synthetic is the way to go.
Make sure you clean up the drum too when you switch.
Bradley-Thornton
Bradley-Thornton
684
1,648
Hattiesburg MS
X2 This is what I have had for years and for the price if your really worried buy 2
Scamih
183
464
Marshall Illinois
Another question. If you can’t tell. I’m new to the sxs world. I’m figuring out that if have a question of how to do something somebody else has already figured it out. What’s the best way to use your winch to get a deer in the back of your 1000?
Bradley-Thornton
Bradley-Thornton
684
1,648
Hattiesburg MS
I put this in google
honda pioneer 1000-5 deer in back
and liked this ne the best (google is your friend)
Scamih
183
464
Marshall Illinois
I was thinking a pulley or roller mounted high enough off front bumper to clear hood then a pulley hanging down the front and rear roll bar. Then lift the deer up into the bed with the winch. I’ve got a windshield that opens all the way I think I could rig it up.
64,680
I looked also as I thought someone did this before.
For just a deer and not recovery. I think a custom built roller on a tube that slid over the bumper tube and allowed you to clear the window all together may be something to look at.
Kinda like this. The green is a pipe with a roller or something smooth on the end to change direction. at the top B pillar woudl be a pully.
1595203603038
Reactions: 1Ktrailrider
Scamih
183
464
Marshall Illinois
That’s an idea too. It may be easier to mount the pulley on the tube then on a bar going up to clear the hood. The more I think about it and after looking at your picture I think one pulley on the back roll bar would do it. I just went and looked at it , I’m going to use a piece of square tubing and mount it to both bumper cross bars with ubolts, put a plate on bottom so it sets on top of fairlead. I’m going to Rig an old fairlead up on top as the roller. Put a snatch snatch block pulley on the back roll bar. I will run the winch rope through the cab with windshield swing all the way up. I’ll share pictures if it works.
Scamih
183
464
Marshall Illinois
I’m going to make a riser. I’ve got an extra winch bracket that I’ll use as base, weld square tubing to it secure to the bumper with ubolts. I’ll share a picture when I’m done. I think it’s going to work. I am going to run the cable straight to the back roll bar and use the snatch block pulley that came with my winch . I think I’ll have 20$ in it when I’m done. I plan to keep this pioneer forever and I plan to kill a lot of deer and haul them with it.
1Ktrailrider
1Ktrailrider
183
282
Pennsylvania
I wonder if anyone had tried using 3/8" synthetic line over the 1/4"? Probably have to drill the hole in the barrel out but I had to do that on another with when going from cable to synthetic.
BigOL3
BigOL3
2,994
8,919
I have several of those, one being 18K for winch on rear of skidsteer.
Ohio4x4
Ohio4x4
I brought the dishwasher
1,502
15,102
I bought a 3/8" line and could only get about 30' on my spool. I went back to the 1/4" on the winch and kept the 3/8" for an extension cable.
Reactions: BigOL3 and TripleB
Bradley-Thornton
Bradley-Thornton
684
1,648
Hattiesburg MS
How often do you replace them? Btw I ordered what you suggested.
Had mine for 3 years with no problem. I do clean it after we get home anytime I use it and get mud all over it. I pulled a Razor 4 seater out of some super deep sand just the other day.
